Navigation Unit for 02 Escalade
Results 1 to 9 of 9
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, Navigation Unit for 02 Escalade in Cadillac Escalade Forums; Anyone know where I can find a factory original Navigation unit for an 02 Escalade ?...
    dwight.j.carter's Avatar
    dwight.j.carter is offline Cadillac Owners Connoisseur
    Automobile(s): 2003 Seville STS
    Aug 2004
    Des Moines, Iowa, United State
    37
    2,067
    QuestionNavigation Unit for 02 Escalade
    slk230mb's Avatar
    slk230mb is offline Moderator
    Automobile(s): Now: 2008 STS-V, 1960 Eldorado Brougham Then: 2002 Escalade
    Feb 2004
    Bayside, NYC
    31
    5,826
    Re: Navigation Unit for 02 Escalade
    You won't be able to, it wasn't an option. The NAV systems for the 03+ won't work either b/c the wiring is not the same. Your best bet is aftermarket.
    ~Steve
    rokum99's Avatar
    rokum99 is offline Cadillac Owners Fanatic
    Automobile(s): 2007 Black Escalade EXT
    Apr 2004
    Mechanicsburg, PA
    62
    106
    Sorry, but he's right. Can't be done with factory unit.
    Aug 2004
    37
    2,067
    Can't I run the wiring for it from the 03 if I get the parts ?
    slk230mb's Avatar
    Feb 2004
    Bayside, NYC
    31
    5,826
    I doubt it. I'm pretty sure the radio system changed over from 02 to 03. Also we don't have VSS for the NAV so the updating would be based on the GPS, which can get choppy. Also the steering wheel controls changed so you would probably loose those too.
    ~Steve
    rokum99's Avatar
    Apr 2004
    Mechanicsburg, PA
    62
    106
    Your Body Control Module would have to be changed. It needs to be a Data Class II, to communicate with the radio. The cost would out weight the install.
    clickart is offline Cadillac Owners Fanatic
    Sep 2003
    190
    If u get the aftermaket all-in-one unit, do you have to change the speakers? I heard you have to change the speakers because the factory is 2omhs and aftermarket is 4?.
    slk230mb's Avatar
    Feb 2004
    Bayside, NYC
    31
    5,826
    I think you can use an interface to make up the difference.
    ~Steve
    Sep 2003
    190
    If u want to install the aftermarket and keep your bose system, than you need to buy a interface or something like that.
  12. Remove Advertisements
