Problems starting 2003 Cadillac Escalade
Results 1 to 8 of 8
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, Problems starting 2003 Cadillac Escalade in Cadillac Escalade Forums; Ok so ive been having problems starting my escalade it would just sit there and not make an attempt no ...
    jakemcc1774's Avatar
    jakemcc1774 is offline Cadillac Owners Member
    Automobile(s): 2003 Cadillac Escalade 1994 Cadillac Seville 1 more
    Aug 2013
    Arizona/Colorado
    12
    Ok so ive been having problems starting my escalade it would just sit there and not make an attempt no cranking nothing to start and i would have to either rock the truck or shift furious to get the starter to click on once it clicked on no problem so thinking it was that i replaced the starter and it was running smooth for a couple of months and just started doing it again and just today the truck broke down the truck wouldnt shift at all it was moving freely luckily it was after picking my gf up 4 lunch and i didnt have work all day after that to check it out but found out the transmission linkage was broken so gotta custom order one of those from GM Napa dont have them surprisingly but what im wondering is could it of been the linkage breaking slowly that was not letting it start or should i check another place like a good ground on the starter? wiring issue? any other ideas would be great so i can start on the right foot tomorrow to fix it all at once any answer is very appreciated.
    Thank you
    Jake M
    the cadillac man's Avatar
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by jakemcc1774
    Thank you
    Jake M
    It is possible that it was in a position that wouldn't allow the engine to start
    I would still check the battery connections to be sure they are clean and have good contact
    Aug 2013
    Arizona/Colorado
    12
    Re: Problems starting 2003 Cadillac Escalade
    Ya thats what i was thinking it could of been like it wasn't in park when i tried cranking, when i put the new linkage in ill see if it helped at all and yes ill check the battery too gonna be working on alot of stuff with that truck tomorrow thanks for the input
    Mar 2011
    speedwell tn,
    11,884
    I hope you can get it fixed so you can enjoy it instead of having to work on it
    Aug 2013
    Arizona/Colorado
    12
    Quote Originally Posted by the cadillac man
    Around 70 for the two replacement links from GM wasn't too hard of a process but sure got some burns from the exhaust and everything else hot from the Arizona sun but so far so good got it in and running now well wait and see if that was the main problem or not.
    bigirb2002 is offline Cadillac Owners Fanatic
    Automobile(s): 05 escalade
    Mar 2013
    31
    119
    had this issue twice. i had to redo ground. second time battery terminal wasnt tight
    Aug 2013
    Arizona/Colorado
    12
    Ok so 8 days into the transmission linkage replacement haven't had the starting problem yet and before it was almost a daily problem think that might have been the problem in the beginning thanks everybody and anybody who had the kind of problem ive been having take notes check it yourself before you go taking it to a shop
    Mar 2011
    speedwell tn,
    11,884
    Glad to hear that you got it fixed
  11. Remove Advertisements
