McGaughy's drop kit rear suspenstion installtion problem
Results 1 to 3 of 3
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, McGaughy's drop kit rear suspenstion installtion problem in Cadillac Escalade Forums; After getting some help from here I successfully installed front kit of McGaughy's. Now working on back. Everything went well ...
    icaddy is offline Cadillac Owners Fanatic
    Sep 2012
    43
    137
    After getting some help from here I successfully installed front kit of McGaughy's. Now working on back. Everything went well until I was trying to install shock extender to shock mount. For some reason it seems the shock extender was too narrow and won't fit the shock mount. Anyone has ever had the same issue and how did you resolve this problem? My truck is 05 Escalade base.
    Thank you in advance
    Sep 2012
    43
    137
    Re: McGaughy's drop kit rear suspenstion installtion problem
    Answering my own question: got a grinder from HF and grind two sides of the shock mount. When shock extender can BITE the shock mount, use a hammer to punch it in.
    Another question: What is #1 in picture used for? I think #2 should sit at bottom of original shock mount, correct?
    Sep 2012
    43
    137
    Figured it out myself again. #1 is the spacer between stock shock mount and McGaughy's shock mount.
