Brake light, tail light, blinker cruise control problem HELP!!!
Results 1 to 9 of 9
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, Brake light, tail light, blinker cruise control problem HELP!!! in Cadillac Escalade Forums; *Durring the day with lights turn off. * The turn signal turns off the cruise control. * The turn signals ...
    Darrel74 is offline Cadillac Owners Member
    Automobile(s): 2004 Cadillac Escalade ESV
    Aug 2013
    42
    4
    * The turn signals turn work but when I hit the break they speed up and they turn into hazards in the back
    *At night with lights on.
    * Tail lights are on but dim (Top bulb has both filaments lit up but still dim...weird) when brakes are hit the bottom light turns off, the top light goes from 2 filaments to 1 and remaims dim.
    * Cruise control will not work at all
    * The LEDs on mirrors are slightly illuminated.
    * Blinkers basically don't work at all.
    jaypyrnnnm is offline Cadillac Owners Member
    Aug 2013
    3
    Quote Originally Posted by Darrel74
    I have the same exact problem also the reverse sensors lights are red as if I'm reversing on my 02 ext. took it to two different mechanics and they couldn't figure it out I also tried to trace almost every wire to see if anything was damaged or crossed to no avail. Please help can't figure it out.
    the cadillac man's Avatar
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by jaypyrnnnm
    The back up sensors are on a different module which does have a test mode
    Let me know if you need the test method for the park sensors
    Aug 2013
    42
    4
    Re: Brake light, tail light, blinker cruise control problem HELP!!!
    Does yours have an after market alarm or auto start?
    Aug 2013
    42
    4
    Yes, after market auto start.
    TLMC is offline Cadillac Owners Member
    Automobile(s): 2011 Escalade 1969 ss396 chevelle 1967 GTO
    Nov 2011
    BOYNTON BEACH,FL
    62
    76
    It's a ground issue, check the grounds.
    Skier-24 is offline Cadillac Owners Fanatic
    Automobile(s): 2005 Escalade ESV, White Diamond Pearl
    Jun 2013
    Chesterfield, VA
    56
    276
    Quote Originally Posted by TLMC View Post
    I was thinking the same thing.
    Outlaww01 is offline Cadillac Owners Member
    Automobile(s): Escalade
    Feb 2016
    51
    1
    Where are the grounds
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by Outlaww01
    the ground for the rear lights is on the left rear body mount
    Don't forget to check the junction block under the right rear quarter panel
  12. Remove Advertisements
