change engine oil alert problem
Results 1 to 12 of 12
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, change engine oil alert problem in Cadillac Escalade Forums; hello everybody, do you know how to disable the "change engine oil soon" alert after having changed it? thanks a ...
    camilla67 is offline Cadillac Owners Member
    Automobile(s): escalade sport luxury
    Aug 2013
    49
    1
    hello everybody, do you know how to disable the "change engine oil soon" alert after having changed it? thanks a lot!
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,891
    Re: change engine oil alert problem
    Let's move this to the Escalade forums. This CCC forum is for warranty and dealer interaction problems.
    You might want to read your owner's manual - the OLM reset is discussed there. Basically I believe that, in your vehicle, you call up OLM in the DIC and hold the INFO RESET button for 5 or more seconds.
    Please update your profile to show your vehicle year - it sure helps with problem diagnosis.......... if this is in the incorrect Escalade year group, you now know why.
    the cadillac man's Avatar
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by camilla67
    If it is a 02 you turn the key to run and pump the gas three times
    If it is a 03 and newer then the steering wheel controls can be used
    Use the button that has a gas pump on it to bring up the oil life meter then press the enter key till it shows oil life reset the it will display oil life : 100%
    rfishoutofwater is offline Cadillac Owners Fanatic
    Automobile(s): 2005 Escalade EVS Platinum Rip Tide Blue
    Jul 2012
    44
    164
    Mines an 05 and to reset mine i have to pump the gas peddle 3 time. The reset from the steering wheel doesnt work
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by rfishoutofwater
    Odd gm must have played around with it over the years
    wesyder's Avatar
    wesyder is offline Cadillac Owners Connoisseur
    Automobile(s): 08 Escalade ESV awd, 05 Yukon Xl Denali awd, 06 SRX sold
    Mar 2009
    Eastvale Calif
    1,797
    Same here
    mikedyk43's Avatar
    mikedyk43 is offline Cadillac Owners Fanatic
    Automobile(s): 2006 Escalade
    Sep 2011
    Mission Viejo, CA
    38
    470
    Same on my 06
    BlueOvalKid is offline Cadillac Owners Member
    Automobile(s): 2005 Escalade ESV Platinum
    Jun 2013
    41
    26
    Mine's an 05 and the steering wheel reset in the proper DIC menu works fine. Just did it last week.
    jnrsesv is offline Cadillac Owners Enthusiast
    Automobile(s): '05 ESV Platinum
    Feb 2010
    Sunny South Carolina
    907
    Quote Originally Posted by BlueOvalKid View Post
    This is how ours works as well, I have never done the peddle pump reset thingy in our '05 either.
    Jul 2012
    44
    164
    The reset on the wheel wont work on mine. Just the peddle pump works. Kinda odd there are different ways on same year escalades. The reset on the wheel works for everything else though.
    Mark Edward Morrison's Avatar
    Mark Edward Morrison is offline Cadillac Owners Fanatic
    Jun 2012
    419
    My 04 works perfect with the steering wheel controls. You do have to hold it down for like 30 seconds to make it switch back to 100%. I would try it again next time you get your oil changed and just hold it in for 30 to 45 seconds....
    Jul 2012
    44
    164
    Quote Originally Posted by Mark Edward Morrison
    No dice. Tried it several times. Gas peddle only option that works. Manual says gas peddle too. Have had if for over a year.
  15. Remove Advertisements
