Results 1 to 9 of 9
Thread: Help! Stripped wheel hub bolt
    Sep 2012
    43
    137
    So I ordered the McGaughy's 33047 lowing kit and start to work on front suspension last weekend... removed wheel hub center nut with no problem, while removing the three wheel hub nuts on the back of hub is pain ... end up with stripped bolt at 12 o'clock position. There isn't much room over there. Any good idea to remove that bolt?
    Here is the picture, not very clear though. it's 15 mm.
    https://docs.google.com/file/d/0BzZs...it?usp=sharing
    BlueOvalKid is offline Cadillac Owners Member
    Automobile(s): 2005 Escalade ESV Platinum
    Jun 2013
    41
    26
    Re: Help! Stripped wheel hub bolt
    Take the entire spindle off and remove the bolt while you can get at it properly.
    Sep 2012
    43
    137
    Quote Originally Posted by BlueOvalKid View Post
    what do I need to remove prior to removing the whole spindle assemble? tie rod? CV joint? ball joint?
    Many thanks
  5. #4
    bigirb2002 is offline Cadillac Owners Fanatic
    Automobile(s): 05 escalade
    Mar 2013
    31
    119
    Since it's stripped. The best way to do this is get a old socket that almost fits over bolt. The hammer the socket on. Then remove bolt. Before u take bolt completelyoff wiggle back and toward to release the socket. Hers a alternative. Get a gator socket or stepper socket . They are readily available at hard ware stores
  6. #5
    Sep 2012
    43
    137
    Quote Originally Posted by bigirb2002 View Post
    The biggest issue is, as I said at the original post, there is not much space around the bolt that I can work with. I actually got a set of damaged bolt remover socket kit from Sears, but after put the socket on there is no space for a breaker bar...
    I checked the spindle last night and I think I will start to remove tie rod, ball joints as BlueOvalKit suggested to remove the whole assembly.
  7. #6
    wake's Avatar
    wake is offline Cadillac Owners Enthusiast
    Automobile(s): 2007 STS-V, 2007 Escalade, 2003 Escalade EXT
    Sep 2003
    Stafford, VA
    812
    One item to remember for future jobs when you replace a hub is to heat the bolt prior to trying to remove it. They have Loctite on them and are much easier to remove if you heat them first.
  8. #7
    Sep 2012
    43
    137
    thanks everyone. Last night I got it off sucessfully
    What I did is to separate tie rod, upper ball joint, and lower ball joint from spindle, and got wheel hub and spindle off together. Now another stupid question: how to separate wheel hub from spindle?
  9. #8
    Jun 2013
    41
    26
    Quote Originally Posted by icaddy View Post
    Once it's unbolted the hub will slide out of the spindle. It may take some persuasion but it will come out. Basically the hub bearing race slides into the bore of the spindle and then is bolted together. Be sure to clean that bore well before reassembly and, since you stripped a couple, make sure you get new bolts and torque them down properly.
  10. #9
    Sep 2012
    43
    137
    Thank you again. The hub got rusted so I spayed some WD40 and used a hammer to tap it out successfully. great~~~~~~~
  • You may not post replies
