Almost blowing engine
Results 1 to 7 of 7
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, Almost blowing engine in Cadillac Escalade Forums; This is going to sound bad but here goes nothing. When I floor the gas pedal I am hitting about ...
    Txao1051's Avatar
    Txao1051 is offline Cadillac Owners Member
    Automobile(s): Escalade EXT
    Feb 2013
    28
    98
    This is going to sound bad but here goes nothing. When I floor the gas pedal I am hitting about 5800-5900 Rpms... I let off the gas to shift. If I didn't it would probably redline is this common? I have the 05 ext
    wesyder's Avatar
    wesyder is offline Cadillac Owners Connoisseur
    Automobile(s): 08 Escalade ESV awd, 05 Yukon Xl Denali awd, 06 SRX sold
    Mar 2009
    Eastvale Calif
    1,797
    Quote Originally Posted by Txao1051
    If u stay in it it should shift, if it goes against the rev limiter you my friend have a problem
    the cadillac man's Avatar
    Mar 2011
    speedwell tn,
    11,884
    I have done that before and as long as the rev limiter doesn't kick in(which it will) then don't worry
    I have done it more then once so I wouldn't worry
    Txao1051's Avatar
    Feb 2013
    28
    98
    Quote Originally Posted by the cadillac man
    So what do I do when it hits the rev limiter? Because you said it will hit it.
    Mar 2011
    speedwell tn,
    11,884
    If it in park and you do then the rev limiter will kick in but if it is in gear then the speed limiter would kick in at a certain speed
    I have yet to hit either
    Jophusp's Avatar
    Jophusp is offline Cadillac Owners Fanatic
    Automobile(s): 2003 Cadillac Escalade XS-500
    Nov 2012
    33
    102
    Re: Almost blowing engine
    I have hit 5900rpm in mine as well. nothing to worry about unless it does not shift after that. JMO.
    bigirb2002 is offline Cadillac Owners Fanatic
    Automobile(s): 05 escalade
    Mar 2013
    31
    119
    These stock lq9 engines are safe on stock internals to 6200rpm. U won't hit that anyway unless ur tuned and raise the limit
  10. Remove Advertisements
