2003 Cadillac Escalade air ride to shocks
Results 1 to 10 of 10
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, 2003 Cadillac Escalade air ride to shocks in Cadillac Escalade Forums; ok so im trying to convert my 2003 cadillac escalade from rear air ride to heavy duty shocks and been ...
    jakemcc1774's Avatar
    jakemcc1774 is offline Cadillac Owners Member
    Automobile(s): 2003 Cadillac Escalade 1994 Cadillac Seville 1 more
    Aug 2013
    Arizona/Colorado
    12
    Cool2003 Cadillac Escalade air ride to shocks
    ok so im trying to convert my 2003 cadillac escalade from rear air ride to heavy duty shocks and been having a problem with it so i went to 4 wheel parts and asked the guy what i could do and he said that because it weighs so much a shock from them would never work because the truck weighs so much and he said the best bet would be to go to a cadillac dealership and buy the stock shocks because they are big enough to hold the weight without sag so im just wondering if anybody knows another way beacuse ive seen escalades with tons of audio equipment in the back and no sag so please let me know if you know a better way
    the cadillac man's Avatar
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by muhfuknjake
    I have factory shocks and no sag
    Arnott industries has rebulit oem shocks for a good price
    BDuncan is offline Cadillac Owners Fanatic
    Automobile(s): Cadillac
    Nov 2007
    233
    Re: 2003 Cadillac Escalade air ride to shocks
    It's really not hard to understand - ARNOTT does not rebuild OEM shocks - they clean and paint old worn out shocks sent in by other owners and sell them with a new air bag. Not rebuilt in any way which can't be done with OEM type shocks.
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by BDuncan
    I know but the ride is the same as it was before my old ones went bad and I have the arnott oem shocks
    mikedyk43's Avatar
    mikedyk43 is offline Cadillac Owners Fanatic
    Automobile(s): 2006 Escalade
    Sep 2011
    Mission Viejo, CA
    38
    470
    Shocks do not hold the weight, the springs do. The shocks absorb the bumps while driving. The stock shocks are "active " which means they are electronically controlled by the CPU to adjust the dampening depending on driving conditions. They additionally have built-in air bags to lift the rear if you add extra weight. If you were to replace them with generic shocks, you would lose the active dampening feature as well as the auto level (airbag) feature.
    Aug 2013
    Arizona/Colorado
    12
    Quote Originally Posted by mikedyk43
    So what kind of springs should i switch to for more weight about 200-300 pounds daily of audio equipment not including ppl heard tahoe springs will fit any others?
    mikedyk43's Avatar
    Sep 2011
    Mission Viejo, CA
    38
    470
    Quote Originally Posted by jake View Post
    I have read that the Tahoe 4x4 rear springs give you an inch or two of lift. Or you could simply get lift blocks and keep the stock springs. My recommendation would be to get aftermarket airbags and connect them to the auto-level already on the truck. They have the helper bags that go inside of the coils of the stock springs, those would probably work great for what you want.
    Mar 2011
    speedwell tn,
    11,884
    I have read that the Tahoe 4x4 rear springs give you an inch or two of lift. Or you could simply get lift blocks and keep the stock springs. My recommendation would be to get afermarket airbags and connect them to the auto-level already on the truck. They have the helper bags that go inside of the coils of the stock springs, those would probably work great for what you want.
    I agree the helper bags would help with extra load
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,827
    jake, I suggest that you contact Admin concerning a username change - You have flagged the Rules and Guidelines filter.
    Aug 2013
    Arizona/Colorado
    12
    Quote Originally Posted by Submariner409 View Post
    I just did now
  13. Remove Advertisements
