DIY Fix for dimming gear selector / indicator PRND321
Results 1 to 1 of 1
Like Tree1Likes
  • 1 Post By CaddyEscalade
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, DIY Fix for dimming gear selector / indicator PRND321 in Cadillac Escalade Forums; I have been having issues with the gear selector dimming randomly, some days I can barely see it. I did ...
    CaddyEscalade is offline Cadillac Owners Fanatic
    Automobile(s): Escalade
    May 2010
    231
    I have been having issues with the gear selector dimming randomly, some days I can barely see it. I did some searching and turns out this is a very common issue with GM trucks in these years. Here is what to do to fix it.
    1 - Remove gauge cluster
    2 - Remove tabs to take it apart, use masking tape to mark the existing position of your needles and pop them off with a screwdriver (there are many detailed DIYs on how to do this just do a search for stepper motor replacement).
    3 - There is a bank of 7 511 black resistors to the left side below the main plug. There are 3 in a row and below there are 4. See the attached pic.
    4 - Using a fine tip soldering iron just re-flow each side of each resistor (I put a touch of flux on each side prior to heating).
    5 - Put everything back together and it will be as bright as the day it was new.
    Hope this helps.
    jnrsesv likes this.
  3. Remove Advertisements
