Brake rotors which to get
Results 1 to 15 of 15
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, Brake rotors which to get in Cadillac Escalade Forums; Ok I am in need of new brake rotors soon on the rear axle(maybe new pads) Which kind are some ...
    the cadillac man's Avatar
    Mar 2011
    speedwell tn,
    11,884
    Which kind are some you guys using
    I am thinking of a drilled rotor set but I like the looks of the slotted and drilled set
    I am getting them from the r1 concepts vendor on here
    MrHolland's Avatar
    MrHolland is offline Super Moderator
    Automobile(s): 2010 Platinum Escalade, 1996 Fleetwood Brougham
    Jul 2010
    Midwest
    5,685
    Re: Brake rotors which to get
    Although not from a "local" vendor, I've enjoyed rotors from brake performance. I opted for slotted and dimpled, they have a great warranty.
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,323
    If you're making consecutive high speed stops, or towing down long hills, you might benefit from slotted rotors. There's really no benefit to the weight savings of cross drilled rotors on a in a full size SUV. Also, realize that the more slots, dimples, and/or holes in the rotors, the less surface area there is. Which means braking force will be REDUCED.
    Solid or slotted rotors, and some performance ceramic pads would be the best way to go.
    Also, if you're changing the rotors, you NEED to install new pads.
    Mar 2011
    speedwell tn,
    11,884
    So far I have just got a price list as I am still shopping around
    I will be looking at many different places
    I see someone has posted another vendor so I will check them out
    Again I am going to get new pads to go with the new rotors(the ones on the truck may be worn by then)
    Keep the suggestions coming guys as I don't want to get just anything on the truck only to have trouble later on
    My rear rotors are due to be changed and I wish I had done when I had the rear brakes changed
    The heavy pulsing is getting annoying and I know its not the abs alone
    I do tow a trailer sometimes that's why I started the thread so I can get some guidance to make my decision
    mikedyk43's Avatar
    mikedyk43 is offline Cadillac Owners Fanatic
    Automobile(s): 2006 Escalade
    Sep 2011
    Mission Viejo, CA
    38
    470
    Have you considered just getting the stock rotors turned (resurfaced)? Had my rotors turned a little while back for about $25 a piece. Good as new...
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by mikedyk43
    They can't as I asked last time I had it in the shop(too thin to resurface) the mechanic said it would cause other problems(not sure on that)
    Resurfacing was my first option but the rotors are too far gone to do that
    My front brakes (as odd as it sounds) have yet to give me an issue I do keep a check on them though along with the rear
    I have ceramic pads in the rear brakes and I broke them in properly(hard to do in a area with a lot of stop and go traffic some times)for the first few weeks hence why I am trying to get new rotors now before its time to replace the rear brakes again
    Sep 2010
    East Boston MA.
    29
    26,323
    Again, if you replace the rotors, you have to use brand new pads, regardless of how old the current ones are.
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by MoistCabbage
    I know I am going to get the pads before I have the rotors put on the truck
    I am just going to wait till the pads on the rear wears out(they still have half the material left)
    I am going to replace my park brakes at the same time(they haven't held since I got the truck)
    flyingdutchman is offline Cadillac Owners Fanatic
    Oct 2004
    352
    Centric
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by flyingdutchman
    Centric
    Never mind I google searched it
    caddydaddy's Avatar
    caddydaddy is offline Cadillac Owners Connoisseur
    Automobile(s): 2005 Escalade 6.0L 2WD, 2007 Jeep Grand Cherokee Limited CRD
    Jan 2003
    Gales Ferry, CT
    35
    3,717
    I installed EBC - 3GD Sport Rotors (GD7047) on the front with EBC pads. Stops really well now!
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by caddydaddy
    Is it possible you can provide a link for them?
    caddydaddy's Avatar
    Jan 2003
    Gales Ferry, CT
    35
    3,717
    Quote Originally Posted by the cadillac man View Post
    Sure, here is where I bought them. They seemed to have the best price.
    http://thmotorsports.com/ebc_brakes/...s/g-63415.aspx
  16. #14
    Sep 2010
    East Boston MA.
    29
    26,323
    You can also try www.placeforbrakes.com. Use the discount code at the top of the page.
  17. #15
    caddydaddy's Avatar
    Jan 2003
    Gales Ferry, CT
    35
    3,717
    I didn't see the discount code, but they wanted $74 a set more than the place I listed.
  18. Remove Advertisements
