Fluids - What do I need and how much of it?
Results 1 to 6 of 6
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, Fluids - What do I need and how much of it? in Cadillac Escalade Forums; Hi Guys, I know all I seem to do is ask for help but you all seem to know exactly ...
    John P is offline Cadillac Owners Fanatic
    Automobile(s): 2004 Escalade 6.0
    Feb 2009
    Glasgow, Scotland
    159
    Hi Guys, I know all I seem to do is ask for help but you all seem to know exactly whats best and what does the job well.
    Im going to change all the fluids on the Escalade along with spark plugs and oil and air filters. Is there anything else I need to change?
    But my main question is;
    What engine oil and how many litres?
    What transmission oil and how many litres?
    What transfer case oil and how many litres?
    What front and rear diff oil and how many litres?
    I have done a search but its hard to work out whats what and whats needed...so confused. Im in Scotland so trying my best to figure out quartz etc so if you know litres then that would be amazing haha.
    Thanks
    John
    the cadillac man's Avatar
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by John P
    Thanks
    John
    The engine takes 6 quarts
    There is a sticky for the front and rear diffs
    The transmission fluid isn't recommended unless the transmission needs service as it is best to replace filter in the transmission at the same time
    YoshiMan's Avatar
    YoshiMan is offline Cadillac Owners Fanatic
    Automobile(s): 1975 Coupe Deville D'Elegance
    Oct 2012
    Denver, CO
    32
    261
    Re: Fluids - What do I need and how much of it?
    What year is yours John P?
    I can tell you the 03's take 75w-90 SYNTHETIC gear oil in the differentials. I can;t tell you how many liters, but its about 3 quarts in the front, and the back is like.... 5 or so i think.. The rear diff is a PAIN to do because (at least on mine) there is no drain plug and you have to pull the differential cover to drain it.
    The transmission and transfer case specify Dexron-III ATF fluid. The T-case takes a little over two quarts if i'm not mistaken, and the Transmission i couldn't tell you, because i rounded the hell out of the drain plug and now may have to drop the whole pan to fix it... OOPS!
    Feb 2009
    Glasgow, Scotland
    159
    Mine is a 2004 I'm sure.
    Thanks for you reply, Very helpful!
    Mar 2011
    speedwell tn,
    11,884
    Guys I can check my service manual and see what it calls for the tranny fluid level
    wesyder's Avatar
    wesyder is offline Cadillac Owners Connoisseur
    Automobile(s): 08 Escalade ESV awd, 05 Yukon Xl Denali awd, 06 SRX sold
    Mar 2009
    Eastvale Calif
    1,812
    Quote Originally Posted by YoshiMan
    For a 2005 i show
    Trans 5 qts with pan drop
    Front diff 1.51 qts
    Rear diff 2.15 qts
    Transfer case 1.5 qts
  9. Remove Advertisements
