99 escalade wont shift out park when running but will with key in acc position
Results 1 to 5 of 5
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, 99 escalade wont shift out park when running but will with key in acc position in Cadillac Escalade Forums; Newbie here.... 2 questions 1. The truck wont shift out of park when the vehicle is started but it will ...
    Rybruce33 is offline Cadillac Owners Member
    Automobile(s): 99 escalade
    Jul 2013
    33
    4
    1. The truck wont shift out of park when the vehicle is started but it will when the truck is off and key os in the accesories position... I'm thinking some sort of neutral or brake safety switch??
    2. My blower only works on high I'm assuming it's the resistor? Where exactly is the resistor located? I've tried researching it and haven't found ANYTHING.
    Thanks in advance!!
    the cadillac man's Avatar
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by Rybruce33
    Thanks in advance!!
    Not sure on the safety switch but it may be the key switch
    The blower resister would be close to the blower inline and mounted to the hvac box before the heater core and evaporator as it would need to be kept cool while in use
    Jul 2013
    33
    4
    Re: 99 escalade wont shift out park when running but will with key in acc position
    Anybody else on the shifting issue??
    dgriffin is offline Cadillac Owners Member
    Automobile(s): 2000 escalade
    Jul 2013
    51
    my 2000 escalade started the same way but now it is stuck in park and will not shift regardless of the vehicle being on or in the accessory mold. From all the research i have done it appears to be the shift brake actuator sensor. i had to purchase the part from the dealer and occurs it doesn't come with instruction. I know it is located above the brake pad i was hoping to get assistance from someone on this site in getting step by step instruction on removing and replacing the actuator/sensor but no one has replied yet.....
    Jul 2013
    33
    4
    It was the brake light sensor. But make sure you bu the clip because it doesnt come with it. The part is hidden way up under the dash.
  8. Remove Advertisements
