No brakes!!!!
Results 1 to 2 of 2
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, No brakes!!!! in Cadillac Escalade Forums; I have a 99 Escalade with brake problems. I have replaced the right and left front calibers, the master cylinder ...
    shawnte is offline Cadillac Owners Member
    Automobile(s): 1999 Escalade
    Jul 2013
    1
    AngryNo brakes!!!!
    I have a 99 Escalade with brake problems. I have replaced the right and left front calibers, the master cylinder and the brake booster and still have no brakes. I even did a bench bleed on the brakes. Closed all the lines and open them again. Still nothing. I had brake fluid coming out of the master cylinder and fixed that problem. Now I have NO fluid from the ABS to the rear wheel. Please HELP!!!
    Skier-24 is offline Cadillac Owners Fanatic
    Automobile(s): 2005 Escalade ESV, White Diamond Pearl
    Jun 2013
    Chesterfield, VA
    56
    276
    Re: No brakes!!!!
    Have you opened the bleeder screws on the rear calipers and bled the air out of them?
