DROVE THROUGH WATER TRUCK BARELY WILL DRIVE Help
Results 1 to 7 of 7
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, DROVE THROUGH WATER TRUCK BARELY WILL DRIVE Help in Cadillac Escalade Forums; I drove my 2002 escalade through some water it was quite a bit it was raining really hard. it then ...
    jcobra99 is offline Cadillac Owners Member
    Automobile(s): 2000 Cadillac Seville
    Feb 2009
    21
    I drove my 2002 escalade through some water it was quite a bit it was raining really hard. it then started to hesitate and would barely drive when i pressed the gas. Let it fry out a few days and it still dosent drive right. I can get it goin and drive a mile or so but then it will die. Any ideas of what to do. I know id didnt hydrolock it will start and run.
    the cadillac man's Avatar
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by jcobra99
    A hydrolocked engine will still start and run(poorly) you just won't know it did
    There was another member on here who did the same and it totaled his truck because it bent a connecting rod on one of the pistons
    Remove the top of the air intake box if there is water in there(or was water in there) your engine may have suffered
    Other then that it would be electronic issues(PCM failure) but that wouldn't let you even start the truck if it failed
    Feb 2009
    21
    Re: DROVE THROUGH WATER TRUCK BARELY WILL DRIVE Help
    Any other ideas?
    Mar 2011
    speedwell tn,
    11,884
    Any other ideas?
    Nope
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    Check the plug wells and coil connections for water.
    Feb 2009
    21
    I got it to run a little bit. I can drive it around for like 5-10 minutes it still hesitates but does rev up. In idle i can rev it up all the way dosent sound like a bent rod.
    dkozloski's Avatar
    Jul 2004
    Fairbanks, Ak
    28,241
    It sure sounds like you hydrauliced it.
  10. Remove Advertisements
