Escalade EXT engine swap
Results 1 to 3 of 3
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, Escalade EXT engine swap in Cadillac Escalade Forums; Why are the engines out of the newer generation EXT's (2007 and up) not compatible with the older EXT's. (2002 ...
    jreed012 is offline Cadillac Owners Member
    Automobile(s): 2004 ext 1990 allante
    Jul 2013
    1
    Why are the engines out of the newer generation EXT's (2007 and up) not compatible with the older EXT's. (2002 2006) What would have to be swapped out other than just the engine to make the the trade work. Asking because there are many of the newer engines available with low miles. Seems to be a shortage of the older engines available with low miles.
    the cadillac man's Avatar
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by jreed012
    Why are you wanting to swap out your engine?
    There is differences between the two
    The mounts would most likely need swapping between the two and the PCM is different for the newer engine(not compatible with our trucks)
    In all respects you would benefit more from a newer truck vs doing the engine swap
    mikedyk43's Avatar
    mikedyk43 is offline Cadillac Owners Fanatic
    Automobile(s): 2006 Escalade
    Sep 2011
    Mission Viejo, CA
    38
    470
    Re: Escalade EXT engine swap
    You might want to read this article that talks about how to simply bolt on 07+ heads to the older block for increased performance. http://www.superchevy.com/technical/...e/viewall.html
