Airconditioning Problems
Results 1 to 5 of 5
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, Airconditioning Problems in Cadillac Escalade Forums; My 2002 Escalade EXT had been blowing cool (not cold) air intermittently. So i have done the following without any ...
    nhnh is offline Cadillac Owners Member
    Automobile(s): Escalade EXT
    Jul 2013
    My 2002 Escalade EXT had been blowing cool (not cold) air intermittently. So i have done the following without any tangible results:
    1) Changed the compressor
    2) Filter
    3) Air mixing bottle (dont know what its called)
    4) The AC / Compressor shut off switch
    5) Cancelled the heater by making the in/out pipes into a loop
    6) Changed the Blendor Actuator under the glove compartment
    Yet no tangible results.
    Feel that the air is being forced into the front vents.
    Need HELP!!!!!
    the cadillac man's Avatar
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by nhnh
    2) Filter
    Need HELP!!!!!
    Have you replaced the cabin air filter?
    Jul 2013
    Re: Airconditioning Problems
    No. Just cleaned them with pressurised air... Will that help in getting more air pressure through the front air vents?
    Mar 2011
    speedwell tn,
    11,884
    Never clean those they have to be replaced
    Pitbull14218 is offline Cadillac Owners Fanatic
    Automobile(s): 2002 White Diamond EXT
    May 2012
    124
    You sure you have the right charge of refrigerant? Did you evacuate the system before charging?
  8. Remove Advertisements
