Results 1 to 6 of 6
Thread: 2000 escalade stalling out
    adr83 is offline Cadillac Owners Member
    Automobile(s): 2000 escalade
    Jun 2013
    33
    3
    Hey everyone. Been lurking in the shaddows for a bit. 2000 escalade recently started stalling out truck. The problem began a few weeks ago we went camping and on the way the road consisted of multiple up hill stretches. Truck first looses power, then dies. Codes read were the mad, plugs and o2 sensor. I cleaned the maf and throttle body as I read they are suspect. Then replaced
    Maf as stalling continued. Truck doesn't always stall out.. they wife says she noticed that its been happening when the gas gauge reads less than a 1/8 of a tank. But its not stalling cause of no
    Gas. It starts back up after cranking for 2-5 seconds longer than usuall. I was starting to think
    Maybe bad fuel filter. Fuel pump and fiilter both replaced bout 8 months ago. I'd appreciate any idea guys .. thanks in advance
    the cadillac man's Avatar
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by adr83
    Any strange smells?
    Is the check engine light on or flashing when the truck loses power?
    Is the reduced engine power message displayed (if truck has the message center)
    02 sensors could possibly be wiring(for the 02 sensors) or the catalytic convertors are failing from age
    Longer crank time means bad fuel pump(ps you are slowly killing the pump by letting the fuel level get that low as it needs fuel around it to keep it cool)
    Jun 2013
    33
    3
    Re: 2000 escalade stalling out
    Check engine light went away after using sea foam for throttle body. No message. I've been reading that it might be a clogged fuel sock?
  5. #4
    Mar 2011
    speedwell tn,
    11,884
    It has to be cleaned ever so often as carbon build up will impede its performance(I had it happen to me and had the truck die in the middle of the road as I was making a turn not a good feeling for sure)
  6. #5
    Jun 2013
    33
    3
    Well, I'm back. I ended up taking of the throttle body and sensors to clean em since the problem continued and Engine light returned. Haven't been able to get it scanned again. It seems to only act up when the gas tank sits under a quarter tank. Fuel pump was replaced but im thinking it might be it. It give no other symptoms, just stalls, and sometimes if you let off the gas, it continue to stay running until you either get back on the gas or sharp turn, like and right hand turn.
  7. #6
    Mar 2011
    speedwell tn,
    11,884
    There is a fuel filter on this year of truck and it sounds like it needs replacing
  • You may not post replies
