05 Escalade Blower Module/Resistor
Results 1 to 8 of 8
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, 05 Escalade Blower Module/Resistor in Cadillac Escalade Forums; My sister has an 05 Escalade with a blower problem. It works intermittently & will sometimes stay on even after ...
    Maximln is offline Cadillac Owners Enthusiast
    Automobile(s): 08 STS V8 AWD, 1SG, Platinum Edition
    Jan 2003
    Fresno, CA
    662
    My sister has an 05 Escalade with a blower problem. It works intermittently & will sometimes stay on even after the car is shut off. I've searched the boards & the problem appears to be the blower motor resistor/module. Is there a separate resistor & a separate module or are they the same thing? People appear to interchange them but I have also seen them referenced independently. The resistor appears to be near the blower. If there is a blower module, where is that located?
    Thanks,
    Max
    the cadillac man's Avatar
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by Maximln
    Thanks,
    Max
    Contrar to what most people think the blower is controlled by a module just next to the blower motor
    You will have to remove the hush/kick panel on the bottom of the dash in order to get to the module its held in with three screws(7mm socket if I am not mistaken) one is in a tight spot by the tranny hump remove those screws and the panel will come out allowing access to the blower and module
    reddzspace22's Avatar
    reddzspace22 is offline Cadillac Owners Member
    Automobile(s): escalade ext
    Feb 2013
    San Diego,CA
    27
    7
    Blower motor resister is on the passenger side below the dash/kick panel remove the 3 screws 7mm the panel will come down once panel is removed you will see a few wires going into blower motor with a connector at one end that is the resister along with two 7mm screws holding it into blower assembly. The resisters go bad over time should take care of your problem once replaced
    Jan 2003
    Fresno, CA
    662
    Re: 05 Escalade Blower Module/Resistor
    Thanks for the replies guys. I just checked with the parts department. They are saying that my Escalade has both a resistor & a module. The resistor part # is 22807123 & the module part # is 19260762. Now I'm more confused! lol Anyone have any idea which one does what & where they are located? The parts guy said most likely it would be the resistor. They sell a lot of them.
    Max
    Jan 2003
    Fresno, CA
    662
    I replaced the blower motor resistor. I had to splice the new one in. Everything seemed to go well except that I still have no blower. Do you think it probably the blower motor itself?
    Thanks,
    Max
    Mar 2011
    speedwell tn,
    11,884
    Thanks,
    Max
    Remove the blower and secure it to a table and bench test it with 12 volts it is likely it failed and took out the blower module hence why it won't work now with the new moule
    Jan 2003
    Fresno, CA
    662
    I finally ended up taking the Escalade in to the dealer. It ended up only being a fuse! Now it blows as cold as ever!
    Max
    Mar 2011
    speedwell tn,
    11,884
    I finally ended up taking the Escalade in to the dealer. It ended up only being a fuse! Now it blows as cold as ever! Max
    Glad to hear you got it fixed
    Glad to help
  11. Remove Advertisements
