05 ESV Air Ride Compressor Not Running Even After Replacing
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 18
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, 05 ESV Air Ride Compressor Not Running Even After Replacing in Cadillac Escalade Forums; 2005 ESV Platinum Air ride compressor was not running. To diagnose I looked at fuses and jumped relay pins and ...
    BlueOvalKid is offline Cadillac Owners Member
    Automobile(s): 2005 Escalade ESV Platinum
    Jun 2013
    40
    26
    2005 ESV Platinum
    Air ride compressor was not running. To diagnose I looked at fuses and jumped relay pins and still wouldn't turn on.
    Based on above I bought a replacement compressor from Arnott and replaced it along with rebuilding the dryer.
    Put everything back in and the compressor is still not turning on.
    What do I check at this point?
    the cadillac man's Avatar
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by BlueOvalKid
    2005 ESV Platinum
    There should be a couple fuses in the under hood fuse box check those and also check the stud 1 fuse
    Jun 2013
    40
    26
    Re: 05 ESV Air Ride Compressor Not Running Even After Replacing
    I need to know what is feeding pins 85 & 85 on the relay circuit.
    I have a good 12v on pin 30. If I jumper pins 30 & 87 the compressor will turn on manually now. So, I know my replacement Arnott is ok.
    What is feeding the 85 & 86 lines on the relay to open that circuit to kick on the compressor?
  5. #4
    Mar 2011
    speedwell tn,
    11,884
    Check the rtd fuse in the underhood fuse
  6. #5
    Jun 2013
    40
    26
    I have checked & double checked every fuse under hood and the IGN3 on the interior fuse panel.
  7. #6
    Mar 2011
    speedwell tn,
    11,884
    I would check the connections
  8. #7
    Jun 2013
    40
    26
    Quote Originally Posted by the cadillac man View Post
    Can you elaborate or can anyone else provide some guidance?
  9. #8
    Mar 2011
    speedwell tn,
    11,884
    I was talking about the harness at the compressor check it
  10. #9
    Jun 2013
    40
    26
    Pin 30 has 12v with key OFF
    Pin 85 has 12v with key ON
    Jump either to pin 87 and the compressor turns on (obviously dependent on key position).
    What feeds pin 86 to complete the relay circuit? I'm thinking it has to come from either the compressor or computer to signal the relay to close the bridge to pin 87.
    Does anyone have a wiring schematic for this relay and what circuits control it?
  11. #10
    Mar 2011
    speedwell tn,
    11,884
    Send me a pm with your email(if my inbox is full let me
    Know as the iPhone app doesn't let me
    Know how full it is)
  12. #11
    Jun 2013
    40
    26
    Sent
  13. #12
    Mar 2011
    speedwell tn,
    11,884
    Sent
    Got it
  14. #13
    Jun 2013
    40
    26
    If I'm looking at the schematic correctly then pin 86 of the relay is controlled by the ESC computer, correct?
    I have checked all other pins of the relay and they are working properly.
    Since I don't have any DIC messages would this point to the ESC computer being bad then and I need to replace?
  15. #14
    Mar 2011
    speedwell tn,
    11,884
    I would see if the fuse isn't blown for the module
    You are correct on the pin
  16. #15
    pmartell12's Avatar
    pmartell12 is offline Cadillac Owners Fanatic
    Automobile(s): 2015.5 black premium, sold my black 2003 ESV
    Jul 2010
    London, Ontario, Canada, 11450
    40
    141
    try starting it and putting in in drive... I saw that worked on the million dollar post
  17. Remove Advertisements
