air suspension leak down
Results 1 to 7 of 7
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, air suspension leak down in Cadillac Escalade Forums; Pumps up fine. Leaks down to nothing when towing about 5000 lbs. Any common areas I should look for the ...
    crusher is offline Cadillac Owners Fanatic
    Automobile(s): 2012 Escalade Premium
    Aug 2004
    Jersey Shore
    259
    Pumps up fine. Leaks down to nothing when towing about 5000 lbs. Any common areas I should look for the leak???
    the cadillac man's Avatar
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by crusher
    Spray down the rear shocks with some soapy water while working the rear of the truck while looking for bubbles
    Other then that it could be the valve in the compressor sticking
    wesyder's Avatar
    wesyder is offline Cadillac Owners Connoisseur
    Automobile(s): 08 Escalade ESV awd, 05 Yukon Xl Denali awd, 06 SRX sold
    Mar 2009
    Eastvale Calif
    1,807
    Both my trucks leak down.. I found the leak at the o-ring between the compressor and the dryer, both o-rings were brand new with the new compressor, i changed to a slightly thicker o-ring
    Aug 2004
    Jersey Shore
    259
    Re: air suspension leak down
    Seems to only leak down when I have a load of the hitch. Otherwise it is fine. Strange that the compressor can't keep up with the leak when towing yet I maintain pressure for several days if i don't drive it with no load on the hitch. Hope that made sense.
    wesyder's Avatar
    Mar 2009
    Eastvale Calif
    1,807
    System doesn't compensate once you are moving thats why it leaks down, i can hear mine leak with a load then when i grab the air dryer and move it i can make it stop leaking, i jus pulled the unit from my 05, gonna pickup a thicker o-ring tomorrow
    Aug 2004
    Jersey Shore
    259
    Lets us know if that fixed the problem?
    wesyder's Avatar
    Mar 2009
    Eastvale Calif
    1,807
    So far i installed the o-ring and bench pressure tested it, all is good ill test it with the toy hauler 4th of july weekend, but i believe its ok, previous o-ring didn't pass pressure test
  10. Remove Advertisements
