My 2005 Escalade parking lights will not come on!
Results 1 to 3 of 3
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, My 2005 Escalade parking lights will not come on! in Cadillac Escalade Forums; What to do, they are new bulbs too.........
    aanncorliss is offline Cadillac Owners Member
    Jun 2013
    1
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,919
    Re: My 2005 Escalade parking lights will not come on!
    Moved to the proper Escalade forum.
    the cadillac man's Avatar
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by aanncorliss
    First check the fuses(if the low beams come on then its not the switch)
    Then check the relay in the under hood fuse box(you can swap it around with the horn relay to test it)
    If both are good and work then the switch itself may be bad if it is the switch its easy to replace
    Best way to check is with the key off so you can hear the relays click(I can hear mine inside the cab when they click)
