2004 Escalade Air Ride NOT Level
Results 1 to 4 of 4
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, 2004 Escalade Air Ride NOT Level in Cadillac Escalade Forums; Hi. New to the forums, so Hello everyone!! Just bought a 2004 Escalade with about 67k miles on it. It ...
    wlalone92802 is offline Cadillac Owners Member
    Automobile(s): 2004 Cadillac Escalade
    Jun 2013
    35
    Hi. New to the forums, so Hello everyone!! Just bought a 2004 Escalade with about 67k miles on it. It has 26" rims and the air compressor assembly had been removed previously....So I bought a new air compressor assembly and installed it and only the rear lifts up and now just looks ridiculous. How do I adjust the front shocks to level it out and/or lower the rear ride height to make it not so jacked up?
    Any help would be greatly appreciated.
    Thanks!!!
    the cadillac man's Avatar
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by wlalone92802
    Thanks!!!
    That is the normal ride hight of the escalade as the rear shocks are auto leveling
    You can modify the rear lift/dive sensors some and it will lower the rear back down to what you are used to
    Mine is like this and I don't mind it but the sagging the truck did before you replaced the compressor was because of it not having the load leveling compressor to level out the truck
    It also lowers the rear some at higher speeds to increase stability(I have had mine up to 100mph before and it is very stable yet smooth)
    Jun 2013
    35
    Re: 2004 Escalade Air Ride NOT Level
    Can the front be lifted at all? Are the front shocks electronic and do they allow for much adjustment?
    mikedyk43's Avatar
    mikedyk43 is offline Cadillac Owners Fanatic
    Automobile(s): 2006 Escalade
    Sep 2011
    Mission Viejo, CA
    38
    470
    Quote Originally Posted by wlalone92802 View Post
    The front can be lifted by tightening the tension bolts on the front torsion bars. They are located under the vehicle approx even with the front doors. You will only be able to adjust about two inches before the camber will not be correctable and you will definitely need an alignment after adjusting. An easier fix would be to shorten the auto level dive switch rods that Cadillac Man already mentioned. They can be accessed by removing the rear wheels.
  7. Remove Advertisements
