Air leak test on shocks
Results 1 to 5 of 5
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, Air leak test on shocks in Cadillac Escalade Forums; I have an air leak and can not find it. Does anyone know a clever way to plug the air ...
    CaddyEscalade is offline Cadillac Owners Fanatic
    Automobile(s): Escalade
    May 2010
    231
    I have an air leak and can not find it. Does anyone know a clever way to plug the air line off to test for leaks? Essentially I would like to remove a shock from the system to see if it will hold air. I have tried to spray soapy water and listen and feel for leaks but can't find anything. It is not the air compressor, as it was replaced. Thanks
    the cadillac man's Avatar
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by CaddyEscalade
    You still have a leak in the shocks somewhere lift the rear end with a jack and see if there is a rear in a bladder
    May 2010
    231
    Re: Air leak test on shocks
    Quote Originally Posted by the cadillac man View Post
    Im not sure I understand, im assuming you mean a tear in the bladder? I've checked and everything seems good, the compressor pumps up both bladders and i ut my hands around them and cant feel or hear anything but the truck slowly starts dropping and 30 seconds or so later the compressor kicks back on and lifts up again.
    Mar 2011
    speedwell tn,
    11,884
    I meant a tear(phones auto-check messes up my typing sometimes)
    But the exhaust valve may be sticking in the compressor causing the air to bleed out
    May 2010
    231
    nope, i thought the same thing and bought a new compressor. I have the fuse pulled now so I dont wear it out.
  8. Remove Advertisements
