service ride control issue... new one
Results 1 to 10 of 10
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, service ride control issue... new one in Cadillac Escalade Forums; So I have had my 03 esv for 4 years, and always thought that the air ride was working... the ...
    pmartell12's Avatar
    pmartell12 is offline Cadillac Owners Fanatic
    Automobile(s): 2015.5 black premium, sold my black 2003 ESV
    Jul 2010
    London, Ontario, Canada, 11450
    40
    141
    So I have had my 03 esv for 4 years, and always thought that the air ride was working... the truck has a decent ride, and I have never had any ride control messages appear on the dash.. I pull a medium size boat around, and have not noticed the level sagging.
    A month ago I had my uncle's shop replace both front wheel bearings... they disconected the battery while they did it. When I got it back it had the service ride control message on the dash (5 seconds after starting the truck) they scanned the codes and found that the left rear level sensor was bad.... so i replaced it with a used one.
    The code for the level sensor is gone then the code for the air exhaust solenoid came up.. so i read all 25 pages of the million dollar question thread and was going to remove the compressor to see if i had to solder the copper on the exhaust solenoid like so many others have had to do...
    but before i pulled the compressor off, i thought i would remove the relay under the dash to check the compressor from the engine bay.....i connected the 30 and 87 pins.... and nothing happened.
    I climbed under the truck to see if the compressor's electrical connector was bad and i found this !!!! it looks like something from the titanic!!
    WOW! so I guess my compressor is bad..... hmmm i wonder if my shocks are alright...i take off the valve, and i hook one up to my air compressor... the air whistles right out the bottom... no seal on them at all.
    so the shocks and compressor are useless...... I have been like this since i bought the truck and am willing to live with it... but how did the previous owners get the service ride control message off the dash? and how do I do the same?
    the cadillac man's Avatar
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by pmartell12
    Sometimes the module won't throw the message
    CaddyEscalade is offline Cadillac Owners Fanatic
    Automobile(s): Escalade
    May 2010
    231
    If you leave the compressor installed and wired up, try pulling the Stud1 fuse located under the hood. Worked for me.
    pmartell12's Avatar
    Jul 2010
    40
    141
    Re: service ride control issue... new one
    Quote Originally Posted by CaddyEscalade View Post
    i just tried it, and no luck, the message still came on
    Mar 2011
    speedwell tn,
    11,884
    Try pulling the rtd fuse in the underhood fuse box
    pmartell12's Avatar
    Jul 2010
    40
    141
    Quote Originally Posted by the cadillac man View Post
    i tried pulling the rtd fuse, no luck there either... I am going to see if one of my uncle's mechanics can clear the codes permanently
    Mar 2011
    speedwell tn,
    11,884
    There is two ways one replacing the shocks and compressor the other is pulling the ride control module
    crazymaci's Avatar
    crazymaci is offline Cadillac Owners Member
    Automobile(s): 05 escalade
    Dec 2012
    seattle
    34
    21
    Do it yourself for 600$buy the dorman setup because you cant salvage anything from that to reuse on the arnott pump,and it may "ride ok" but it doesnt ride like a caddy
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by crazymaci
    So true once the ride control system goes passive the ride quality takes a huge blow
    pmartell12's Avatar
    Jul 2010
    40
    141
    well, I Got the answer I was looking for from another forum. I had to remove the negative battery cable, wait 15 minutes, remove the rtd fuse under the hood, wait 2 more minutes, reattach the battery cable, and the message was gone!
  13. Remove Advertisements
