Intermittent Friction Noise
Results 1 to 7 of 7
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, Intermittent Friction Noise in Cadillac Escalade Forums; ...
    seaman.40 is offline Cadillac Owners Member
    Automobile(s): 02 Esacalade
    Jul 2011
    31
    AngryIntermittent Friction Noise
    I replaced my rotors and brake pads on 4 tires, at first there were no noise, but after a month I hear a intermittent friction noise, when I am stopping or turning at low speed ,I cant really tell where is coming from, I only hear it with windows down and no music very
    weak .I can’t stand noises in my car. Any ideas what could be . Thanks in Advance
    the cadillac man's Avatar
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by seaman.40
    Check your rims if they are factory they may be peeling on the chrome
    My 03s factory rims is doing this I had tore the peeling parts off back of this but it is back as I noticed it yesterday while I was at the dealer to get my shocks replaced
    BDuncan is offline Cadillac Owners Fanatic
    Automobile(s): Cadillac
    Nov 2007
    233
    Re: Intermittent Friction Noise
    Can you describe the noise more, high pitched squeal, vibration type sound?? Did you use slotted or smooth rotors? The metal clips at the end of the pad can get out of place during pad install and they can rub the edge of the rotor.
    Jul 2011
    31
    I got no vibrations , the rotors are smooth, its like something is touching the rim or rotor, but I cant find what it is, the rims are basically new, so nothing is
    peeling of the chrome. I probably have to lift the car and go one by one of the tires to see if I can find something.
    Mar 2011
    speedwell tn,
    11,884
    Does it go away while you make turns?
    Jul 2011
    31
    Nope, Actually I hear it when I make turn, but I like I said only hear it at really low speed.
    Mar 2011
    speedwell tn,
    11,884
    Sounds like a cv joint
  10. Remove Advertisements
