escalade won't start, no turning over, onstar works - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 26 of 26
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, escalade won't start, no turning over, onstar works in Cadillac Escalade Forums; Originally Posted by the cadillac man No sound as in no click from the starter or no click from the ...
  1. #16
    mikebux is offline Cadillac Owners Member
    Automobile(s): mikebux@gmail.com
    Oct 2011
    Re: escalade won't start, no turning over, onstar works
    Quote Originally Posted by the cadillac man View Post
    No sound as in no click from the starter or no click from the relay or starter if its the later it may be a bad relay unless a module has gone crazy(I have seen it happen not fun)
    So did they found why it did not start?. I have the same problem
  2. #17
    the cadillac man's Avatar
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by mikebux
    Let me explain no click from the starter or starter relay means something else has failed(it can be a module eg the PCM) I had my PCM fail on me and I got no click from either the starter or the starter relay
    Of corse there is the theft system if the little lock is on (not flashing) then something is triggering the system and preventing you from starting the truck(most likely the pass lock in the key switch
  3. #18
    Cadillac Cust Svc's Avatar
    Mar 2010
    Detroit, USA
    12,711
    Mikebux, I see The Cadillac Man has already been providing DIY advice, and I just wanted to let you know I'm available should you have any lingering questions. My email is Katie_Lucille@gmexpert.com, an dI'm happy to investigate further for you at any point!
    Katie
  5. #19
    pcunite is offline Cadillac Owners Member
    Automobile(s): 2000 Deville DHS
    Dec 2005
    84
    What was the problem?
  6. #20
    mikearch54 Guest
    Same issue. Took it to my mechanic and they kept it for two days. Started fine for them. When I got it back it was fine for a couple of weeks. Now it's back at it again. I notice it happens after it rains. Not sure. Well it's been 5 days and it still hasn't started. The last time I drove it the steering wheel felt like it was pulling to a halt... then it was hard to turn the truck. I smelled a burning smell near the front tires. Hasn't started since. Gotta call a tow now.
    __________________________________________________ ______________
    You might want to update your profile to show correct information ............
  7. #21
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by mikearch54
    Same issue. Took it to my mechanic and they kept it for two days. Started fine for them. When I got it back it was fine for a couple of weeks. Now it's back at it again. I notice it happens after it rains. Not sure. Well it's been 5 days and it still hasn't started. The last time I drove it the steering wheel felt like it was pulling to a halt... then it was hard to turn the truck. I smelled a burning smell near the front tires. Hasn't started since. Gotta call a tow now. __________________________________________________ ______________ You might want to update your profile to show correct information ............
    You may have a wiring issue somewhere that when it rains it shorts out those circuits
    It may have possiblely messed up the PCM in the process(not sure)
    The steering is power steering pump related(been there before)
  8. #22
    broncocrazy is offline Cadillac Owners Member
    Automobile(s): '04 Escalade/'14 CTS
    Aug 2015
    Georgia
    66
    I have the same problem. Battery has 12.8 volts, the car starts all the time, then out of no where it won't start. Cleaned the terminals, checked the voltage, all the electrical system works except the start part of the vehicle. Let me say this, when I say it won't start I mean the vehicle won't even turn over. So it can't be fuel problem. It will sit for about 5 minutes and then it will start. from no attempt to start at all to a complete and efficient ignition. Cadillac has no idea as to my problem and the problem goes away on its own in a few minutes. This has only happened after the car has been driven and a restart is necessary. A first time start has always been good. Any Idea? Cadillac leans toward ignition switch and the tech says he hates to just throw parts at the problem. Not many of those guys left.
  9. #23
    godsdiablo's Avatar
    godsdiablo is offline Cadillac Owners Connoisseur
    Automobile(s): 2005 Cadillac Escalade
    May 2008
    New York
    1,177
    I say check ground cable to engine / add grounding strap should fix it if starter alternator fuel AND battery all checks out OK
  10. #24
    EXT_R1 is offline Cadillac Owners Member
    Automobile(s): 05 EXT 07 DTS
    Mar 2015
    36
    whats the status on this Im having the same issue right now
    knight.jaliek@gmail.com
  11. #25
    AEternal1 is offline Awaiting Email Confirmation
    Automobile(s): escalade
    Apr 2017
    1
    I'm having the SAME problem now. battery at 12.38, theft light goes off after a few seconds. all fuses are good. battery light goes off after a few seconds. i drove it earlier today, always starts right up, no starter strain, like its about to go out. then i go out a few hours later, dead as a doornail. radio etc all work just fine. no starter solenoid sounds, no spinning, nothing. this car has given me absolutely no signs that anything is about to give out. its been a flawless vehicle until this incident.
    so, has anyone figured out what is going on?
  12. #26
    N9LO's Avatar
    N9LO is offline Cadillac Owners Enthusiast
    Automobile(s): 2004 Escalade 6.0
    Jul 2014
    Central Wisconsin
    62
    655
    Try it in neutral... could be park safety switch
    Sent by my Windows PC, a Real Computer...
    Because some people cannot figure out how to turn off the forced advertising on their device.
  13. Remove Advertisements
