Oil gauge broken, easy inexpensive fix?
Results 1 to 4 of 4
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, Oil gauge broken, easy inexpensive fix? in Cadillac Escalade Forums; My Oil gauge on my 05 Escalade has gone bad. It reads as it was full all the time. Is ...
    cpmet200's Avatar
    cpmet200 is offline Cadillac Owners Member
    Automobile(s): 2010 Cadillac Escalade ESV
    Jul 2011
    80
    My Oil gauge on my 05 Escalade has gone bad. It reads as it was full all the time. Is there a way to fix this?
    BDuncan is offline Cadillac Owners Fanatic
    Automobile(s): Cadillac
    Nov 2007
    233
    Re: Oil gauge broken, easy inexpensive fix?
    It's most likely the oil pres. sender located way in back of the intake plenum. It's a fairly cheap part but hard as hell to get to without very long, very skinny arms. Probably under $100 to have a dealer do it.
    Typer2k1 is offline Cadillac Owners Member
    Automobile(s): 2004 Escalade ESV
    Apr 2013
    7
    Could this be caused by a failed stepper motor on the cluster itself? if so you just need a soldering iron and a replacement stepper motor
    the cadillac man's Avatar
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by Typer2k1
    If the needle doesn't move or "pegs" at certain spots then yes the stepper motor is bad(common issue)
  7. Remove Advertisements
