New Escalade ESV owner (any issues to look out for?)
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 29
Like Tree1Likes
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, New Escalade ESV owner (any issues to look out for?) in Cadillac Escalade Forums; Hello All, I recently bought a 2004 Cadillac Escalade ESV on 02/01/13 with 144,726 miles on the ODO This is ...
    hturner0iii0's Avatar
    hturner0iii0 is online now Cadillac Owners Member
    Automobile(s): 2004 Escalade ESV 2008 Escalade ESV
    May 2013
    North Riverside IL
    56
    Hello All,
    This is a list of the work I have had done since owning the truck.
    *Replaced the instrument cluster ($650) (dealership)
    *Replaced the air bag harness under the driver's seat ($450) (dealership)
    *Cleaned the fuel injectors ($100) (Dealership)
    *Replaced the purge Solenoid valve ($200) (personal mechanic)
    *Flushed the coolant ($100) (personal mechanic)
    *Installed new rear air shocks and rear air shock compressor ($2200) (personal mechanic)
    *Installed new gas cap ($20) myself (gas cap from AutoZone)
    * New Pioneer AVIC 150 BH Navigation Radio ($1500) (old navigation was shot) (crutchfield -purchased)(Sound Shop - install)
    This is what I have done so far. Is there anymore issues that I need to be aware of? I will be taking a 2,000 + mile trip in June so I want to be aware if there is anything to look out for. I have always wanted an ESV so far I have been spending a good deal of $ but I got the truck for a good price.
    Any suggestions you guys might have will be appreciated
    Thanks
    YoshiMan's Avatar
    YoshiMan is offline Cadillac Owners Fanatic
    Automobile(s): 1975 Coupe Deville D'Elegance
    Oct 2012
    Denver, CO
    32
    261
    Re: New Escalade ESV owner (any issues to look out for?)
    I think the biggest issue these have is that they burn through the front differential bearings for some reason... but if it is not making noise then i think you are good to go.
    Jophusp's Avatar
    Jophusp is offline Cadillac Owners Fanatic
    Automobile(s): 2003 Cadillac Escalade XS-500
    Nov 2012
    33
    102
    Check the brakes, Particularly the rear brakes for wear, you wont get much notice till the metal is grinding.
    Typer2k1 is offline Cadillac Owners Member
    Apr 2013
    7
    When I got my 04 ESV a month ago I changed the front diff fluid, engine oil, transfer case fluid, and replaced the rear brakes. From what I've read on here the front diff is notorious for failing if not properly maintained. My front diff is making the growling sound now
    bigirb2002 is offline Cadillac Owners Fanatic
    Automobile(s): 05 escalade
    Mar 2013
    31
    119
    1.front diff. if to late rebuild use a good synthetic fluid. i found they get dirty quick without a good syn oil. if u do flush refill with syn flush again after 3k miles then ur good. add a bottle of lubegard gearfluid additive
    2.stepper motors. cause the guages to not work properly but i see u got a new cluster
    3.oil pickup o ring. this causes air to enter in the oil system causing low oil pressure noise. easy fix drop oil pan replace o ring in oil pickup
    4.fuel pump sender. they will go bad. i just got a new pump with updated sender and wiring. all minor issues.
    May 2013
    North Riverside IL
    56
    Is the diff growling sound loud. Will I be able to notice it driving with the radio off ? I don't plan on doing any maintenance myself I'm not mechanically inclined. If I put new diff fluid in it won't damage the diff will it?
    YoshiMan's Avatar
    Oct 2012
    Denver, CO
    32
    261
    So long as you used the correct stuff then no, as alot of time the Differentials NEVER get changed
    May 2013
    North Riverside IL
    56
    Today I listened to the truck as I was driving it. I do hear a sort of rubbing or scrubbing sound from the front as I drive between 20-40 MPH. I will be taking it to my mechanic on Tuesday for diagnosis. Well so much for my road trip 😞
    Jophusp's Avatar
    Nov 2012
    33
    102
    Quote Originally Posted by hturner0iii0 View Post
    Dont get too down about it yet, there are a few dif things that could be causing that. Just wait till you get it checked out.
    May 2013
    North Riverside IL
    56
    Quote Originally Posted by Jophusp
    I will update you guys as to the status. Ill take the truck to my mechanic on Tuesday.
    I'll be taking the truck to my mechanic on Tuesday. I'll update you guys then. Other than the scrubbing sound (which you have to listen hard to hear). The truck runs great.
    the cadillac man's Avatar
    Mar 2011
    speedwell tn,
    11,884
    It could be a wheel bearing so check those as they can sound like that also
    Does the noise go away when you make a turn if yes then its the wheel bearing
    Don't forget the u joints on the drive shafts
    Plus cv joints can do this also
    May 2013
    North Riverside IL
    56
    These are some pictures while I wait to go to the mechanic on Tuesday
    Mar 2011
    speedwell tn,
    11,884
    <img src="http://www.cadillacforums.com/forums/attachment.php?attachmentid=110257"/>
    <img src="http://www.cadillacforums.com/forums/attachment.php?attachmentid=110265"/>
    <img src="http://www.cadillacforums.com/forums/attachment.php?attachmentid=110273"/>
    Nice
    Rims look great
    How did they have it in the showroom floor like that?
    FYI get the Cadillac owners app for your iPhone
  16. #14
    May 2013
    North Riverside IL
    56
    Yes. I have the app for my iPhone. It makes posting real easy. I think the rims are okay but I could have gone for the OEM Cadillac rims. I won't be going any bigger as I have a 98 Yukon with 28" wheels on it and a caprice with 22"s. I want to make this my long distance vehicle and I don't know if it is true with the escalade or not but for my other vehicles the ride quality suffers a little.
  17. #15
    Mar 2011
    speedwell tn,
    11,884
    I have seen people say it does hurt the ride some
    I have the app and I agree is a time saver
  18. Remove Advertisements
