Stability System Activated?
Results 1 to 7 of 7
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, Stability System Activated? in Cadillac Escalade Forums; Hey guys, I have a question about 2002 cadillac escalade. My stability system would activate when turning so i changed ...
    titustogi is offline Cadillac Owners Member
    May 2013
    3
    Hey guys,
    I have a question about 2002 cadillac escalade. My stability system would activate when turning so i changed my wheel sensor and it stopped for 2 weeks. It started again and my mechanic told me the tires were giving off different readings because two tires were bald. So I just replaced all 4 tires and the stability system is still activating when turning on dry pavement. Any suggestions on why this is happening?
    Tdub80 is offline Cadillac Owners Member
    Feb 2013
    6
    Re: Stability System Activated?
    I have the same issue on my '04. Changed wheel hub etc and still doing it. Might be the wire that goes from ABS to firewall. Working on the solution..
    the cadillac man's Avatar
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by titustogi
    Hey guys,
    Could be a bad sensor
    May 2013
    3
    I have replaced the yaw sensor yet it still does it
    Mar 2011
    speedwell tn,
    11,884
    I meant a wheel speed sensor
    reddzspace22's Avatar
    reddzspace22 is offline Cadillac Owners Member
    Automobile(s): escalade ext
    Feb 2013
    San Diego,CA
    28
    7
    Ebcm could be starting to go bad. Did your mechanic check for any dtc's in module??
    May 2013
    3
    I took it to the dealer they changed one of the wheel position sensor and the yaw rate sensor. I dnt know if they calibrated the ebcm after replacing the yaw rate sensor
  10. Remove Advertisements
