AC switched to HEAT while driving. PLEASE HELP
Page 1 of 2 12 LastLast
Results 1 to 15 of 26
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, AC switched to HEAT while driving. PLEASE HELP in Cadillac Escalade Forums; I am in South Florida and its starting to get real hot outside. I have owned my 2004 escalade for ...
    OneLuv1979 is offline Cadillac Owners Member
    Automobile(s): 2004 Escalade
    May 2013
    Wellington,FL
    38
    44
    I have owned my 2004 escalade for all of maybe 2 weeks.
    I was on the interstate today driving and all of a sudden my cold air switched to HEAT.I did everything trying to get the cool air back adjusting controls with no luck it just continued to blow hot heated air.
    30 miles later when I got off I95 I shut the car off and restarted it and bam AC is blowing ice cold again.... Can someone please tell me what the heck I need to do to repair this. Bummed to be already dropping cash on it , I spent everything I had buying it.
    the cadillac man's Avatar
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by OneLuv1979
    It's the driver side temp door actuator
    Remove the kick panel on the passenger side to access it
    I removed mine and took it apart and cleaned the contacts inside and it hasn't done it again
    May 2013
    Wellington,FL
    38
    44
    Re: AC switched to HEAT while driving. PLEASE HELP
    OK Thanks for the quick reply what does this thing look like and where is it located under there?
    I don't mind buying a new one if needed... Just cant have this continue.
    Is there any tricks to remove it?
    Mar 2011
    speedwell tn,
    11,884
    It will be right above the right of the tranny hump(it is black with a wiring harness plugged into it)
    I am going to warn you NOT to have the key on with it unmounted as it can be damaged quick
    There is no tricks to remove it just two screws hold it in place
    Use a ratchet with a 7mm socket(not sure its been so long since I had mine out) to remove the screws and the kick panel pulls out
    FYI there are three screws(one above the tranny hump which is a tight area) that hold the kick panel in place
    May 2013
    Wellington,FL
    38
    44
    Thanks I'm going to wait until it does it again and make sure the passenger and rear ac still work.
    Sounds like a fairly easy repair. Any clue how much a actuator cost?
    Mar 2011
    speedwell tn,
    11,884
    140 bucks
    But the rear air is controlled separately from the front
    May 2013
    Wellington,FL
    38
    44
    I found this on a google search.... Its saying that the passenger actuator is under the kick panel..
    Now im confused.... Is it under the kick panel for sure?
    I drove the lade last night around midnight and I could hear something clicking making noise exactly where u say the actuator is located...
    http://tahoeyukonforum.com/forum/showthread.php?t=15787
    Mar 2011
    speedwell tn,
    11,884
    Where ever you seen that is wrong as I watched the actuator move as I worked the driver temp control the clicking noise is it (mine would sounds like someone knocking on a door) I also have the gm service manual and it shows it there
    The passenger side temp door actuator is on the top of the hvac housing along with the recycle air and vent door actuators(you would have to remove the top of the dash to get to those)
    May 2013
    Wellington,FL
    38
    44
    Cool thanks.. Any chance you have a part number?
    I plan on doing it as soon as I pin point that it is only the drivers side.
    Thanks a lot I truly appreciate the help.
    Mar 2011
    speedwell tn,
    11,884
    You can call a dealer and get it as they can get by the vin on the truck
    May 2013
    Wellington,FL
    38
    44
    Really I will have to give them a shout tomorrow and figure it out...
    Thanks!
    Mar 2011
    speedwell tn,
    11,884
    Thanks!
    Yep I did that before on certain parts
    jnrsesv is offline Cadillac Owners Enthusiast
    Automobile(s): '05 ESV Platinum
    Feb 2010
    Sunny South Carolina
    913
    Well fellows ours started the "knocking on a door" noise a week ago but continued to blow cold AC air (drivers side) until this past Tuesday, when the AC turned to heat (drivers side only), passenger side remained cold AC air.
    I removed the passenger side kick panel, the last 7mm screw is truly a PIA especially putting it back in! As Cadillac man stated the module that controls the drivers vents is located right above the trans tunnel. I used a 7/32" rather than the 5.5mm to remove the module. Again 1 of the screws are a PIA but not as bad as the kick panel.
    I removed the module and pried it open. The contacts were clean as was everything else. I applied white lithium grease to the gears snapped the module back together and reinstalled. I haven't heard the "door knocking" nor had the drivers side AC switch to heat since.
    Crossing my fingers that its another "free fix". I will update if the module fails.
  16. #14
    sprink60's Avatar
    sprink60 is offline Cadillac Owners Fanatic
    Automobile(s): 2005 Escalade ESV
    Aug 2012
    West Palm Beach, Fl
    234
    Quote Originally Posted by jnrsesv View Post
    So let me make sure where this thing is...the kick panel is in front of the door. If the module is above the transmissin hump why remove the kick panel?
    OneLuv...the best deal i have found on parts is Number 1 GM Parts on E Bay. They are actually Roger dean Chevrolet in West Palm on Okeechobee. They will honor the E Bay price at the parts counter...BIG discount.
  17. #15
    65kaiser is offline Cadillac Owners Member
    Mar 2013
    Crystal Beach Florida
    59
    47
    Mine just started doing this as well. I did some checking and the panel you have to remove is below the dash on the passenger side, Kind of like if you were sitting in the passenger seat and lifted your feet your toes would touch it. Not the traditional kick panel just forward of the door.
    I found this helpful. http://www.sparkys-answers.com/2011/...vers-side.html
  18. Remove Advertisements
