Need to change rotors and pads, which ones are good??
Results 1 to 12 of 12
Like Tree1Likes
  • 2 Post By MrHolland
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, Need to change rotors and pads, which ones are good?? in Cadillac Escalade Forums; Well its time to replace front/rear rotors and pads...which ones are good and where can i buy them for the ...
    sosatyme72 is offline Cadillac Owners Fanatic
    Automobile(s): '03 Escalade ESV
    Mar 2013
    44
    192
    Well its time to replace front/rear rotors and pads...which ones are good and where can i buy them for the best price? rockauto? thanks guys!
    MrHolland's Avatar
    MrHolland is offline Super Moderator
    Automobile(s): 2010 Platinum Escalade, 1996 Fleetwood Brougham
    Jul 2010
    Midwest
    5,685
    Re: Need to change rotors and pads, which ones are good??
    Ive had good luck with slotted/dimpled rotors from brakepermance.com and wagner ceamic pads. Rotors have life time warranty against warping and cracking and the pads are low dust.
    Forum vendor R1 Concepts would be another good place to check.
    r1concepts and r1concepts like this.
    BDuncan is offline Cadillac Owners Fanatic
    Automobile(s): Cadillac
    Nov 2007
    233
    For standard rotors, NAPA premium rotors at about $50 are hard to beat. I also use EBC shallow slotted rotors on the rear - EBC developed these to be quiet as opposed to most deeper slotted rotors. I have had very long life with virtually no wear on both of these rotors. For pads I only used Wagner Thermo Quiet Ceramic pads on all of my vehicles, amazing wear, no noise, no squeal and no dust. I replaced my factory original front rotors at about 75-80K miles thinking they were causing a slight vibration under hard braking - turns out it was the rear rotors. My original fronts had almost no wear at all. The rears were hot spotted. Escalades are much harder on rear brakes than fronts - probably brake bias set that way to prevent front end dive of a heavy vehicle.
    Chip Potts is offline Cadillac Owners Member
    Automobile(s): 2003 Escalade ESV
    Sep 2012
    57
    4
    I just bought and installed the Powerstop Evolution Performance Rotor and ceramic pad kit from Summit Racing (PWR-K2015). The rotors are drilled and slotted and matching ceramic pads were included. My braking performance improved significantly (30%-40%). Pedal feel is stronger and eliminated pedal free play. I would recommend the kit.
    Mar 2013
    44
    192
    ok but isnt slotted/ drilled rotors more for show?? I have oem 22"s on mine. what about oem rotors does dealer use Ac Delco as well for parts?
    Rolex's Avatar
    Rolex is offline Super Moderator
    Automobile(s): 2008 Nissan Titan, 1996 Jeep Wrangler
    Arkansas
    41
    12,038
    +1 on NAPA. NAPA sells a pretty good rotor for a decent price.
    I replaced my front rotors with Frozen Rotors and Hawk pads. It's a super upgrade, but not cheap.
    The above post is my 2 cents....nothing more.
    Mar 2013
    44
    192
    what if i went with Napa premium rotors all the way around? is that good or do I need better ones in the rear with the Wagner ThermoQuiet pads?
    This is just a daily drivin family truck, so not sure if I need those performance type rotors??? thanks guys
    MrHolland's Avatar
    Jul 2010
    Midwest
    5,685
    Those rotors and pads will work great!! I only bought my rotors because wifey this ability of warping rotors in everything she drives. Thus far, she has been unsuccessful in destroying these!!!
    the cadillac man's Avatar
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by MrHolland
    I am going to guess she rides the brakes a lot
    Mar 2013
    44
    192
    thanks is there a difference between premium and ultra premium I see on their website for these?
    Quote Originally Posted by MrHolland View Post
    flyingdutchman is offline Cadillac Owners Fanatic
    Oct 2004
    352
    Centric pads and rotors
    sprink60's Avatar
    sprink60 is offline Cadillac Owners Fanatic
    Automobile(s): 2005 Escalade ESV
    Aug 2012
    West Palm Beach, Fl
    234
    EWC Yellow Stuff...big difference in stopping power...but dusty. Best all around= Wagner Thermoquiet. Very little dust and stopping power 85%~905 of Yellow Stuff.
    It's not that the Wagners are bad...it's just that the Yellow Stuff pads are that good.
  15. Remove Advertisements
