Braking issue
Results 1 to 6 of 6
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, Braking issue in Cadillac Escalade Forums; Hi, I have an 02 Escalade and have a problem at very low speed braking. Without fail when coming to ...
    Hetiloak is offline Cadillac Owners Member
    Automobile(s): 2002 Escalade
    Mar 2006
    Clanfield, UK
    44
    19
    Braking issue
    Hi, I have an 02 Escalade and have a problem at very low speed braking. Without fail when coming to a stop, like right before your about to stop, it feels like the abs kicks in, pedal goes soft for a split second and the goes back to normal. This seemed to start happening after the vehicle had been sat up non running for approx 2-3 months. Any easy checks first?
    the cadillac man's Avatar
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by Hetiloak
    Could be the wheel speed sensors
    Mar 2006
    Clanfield, UK
    44
    19
    Ok. One in each wheel. I'm running the car in the UK so there aren't a great deal of specialists around, is it a DIY check?
    Mar 2011
    speedwell tn,
    11,884
    I would just replace them both because if one is acting the other may give troubles later on
    Mar 2006
    Clanfield, UK
    44
    19
    Abs sensors replaced, problem solved. Thanks for the help/advice
    Mar 2011
    speedwell tn,
    11,884
    Glad to help
  9. Remove Advertisements
