WTB: cracked headlights
Results 1 to 6 of 6
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, WTB: cracked headlights in Cadillac Escalade Forums; If someone has some headlights that are damaged on the lenses but the back is fine, I'd like to buy ...
    Pitbull14218 is offline Cadillac Owners Fanatic
    Automobile(s): 2002 White Diamond EXT
    May 2012
    124
    If someone has some headlights that are damaged on the lenses but the back is fine, I'd like to buy them to try to take them a part and use the back side on my headlights that have good lenses but cracked mounting holes.
    Thank you
    YoshiMan's Avatar
    YoshiMan is offline Cadillac Owners Fanatic
    Automobile(s): 1975 Coupe Deville D'Elegance
    Oct 2012
    Denver, CO
    32
    261
    Re: WTB: cracked headlights
    I know sometimes you can put car lens in an oven to separate the lens from the housing, but alot of stuff on the Escalade are sonic welded, so that may not work.
    mikedyk43's Avatar
    mikedyk43 is offline Cadillac Owners Fanatic
    Automobile(s): 2006 Escalade
    Sep 2011
    Mission Viejo, CA
    38
    470
    These headlights can be separated. I have read some did it with an oven, but there are no clear directions on this since oven temperatures and heat consistencies vary. I used a heat gun and a knife to cut through the glue and than after they were opened, I used the heat gun and a flat blade screwdriver to scrap off the remaining glue. Takes some time, but very doable.
    May 2012
    124
    I know the stock headlights can be put in the oven to loosen the glue to pull them apart. If anyone has some headlights that the front are cracked i could try to use the back since my headlight mounting holes on the back of the headlight are cracked.
    godsdiablo's Avatar
    godsdiablo is offline Cadillac Owners Connoisseur
    Automobile(s): 2005 Cadillac Escalade
    May 2008
    New York
    1,177
    I would be interested in buying the orange reflectors when you take them apart
    May 2012
    124
    Anyone have a set that were damaged in an accident, but the back mounts are still good?
  9. Remove Advertisements
