WTH... I just installed a new O2 sensor to fix P0054, cleared, now P0141 is the same?
Results 1 to 15 of 15
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, WTH... I just installed a new O2 sensor to fix P0054, cleared, now P0141 is the same? in Cadillac Escalade Forums; After hammering the throttle across the Florida panhandle on a recent trip, I burned up one of my O2 sensors. ...
    Sentinelist's Avatar
    Sentinelist is offline Cadillac Owners Fanatic
    Automobile(s): 2007 Escalade ESV, Black Raven/black, Platinum wheels, 97k
    Mar 2012
    Dallas, TX
    117
    After hammering the throttle across the Florida panhandle on a recent trip, I burned up one of my O2 sensors. P0054 was the code that resulted. After finding out that was Bank 1 Sensor 2, I ordered a new Denso unit, installed it, and went to have the code cleared, only to have it come right back. OK, maybe some of the image searches online had this backwards. I swapped the new O2 to the other (passenger) side. I should note I accidentally dropped the original O2 sensor I was replacing from about 2'. Put it back on the driver's side. Code cleared, now coming back as P0141! But still Bank 1 Sensor 2?? Or did I miss something?
    I'm highly confused. And annoyed. Since the ESV is now late for its state inspection. Any advice?
    TLMC is offline Cadillac Owners Member
    Automobile(s): 2011 Escalade 1969 ss396 chevelle 1967 GTO
    Nov 2011
    BOYNTON BEACH,FL
    62
    76
    Re: WTH... I just installed a new O2 sensor to fix P0054, cleared, now P0141 is the s
    Check the cat itself. Both of mine went out at about the same mileage you have.
    the cadillac man's Avatar
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by TLMC
    That is possible and it can effect the 02 sensors and foil up your plugs in the process
    wesyder's Avatar
    wesyder is offline Cadillac Owners Connoisseur
    Automobile(s): 08 Escalade ESV awd, 05 Yukon Xl Denali awd, 06 SRX sold
    Mar 2009
    Eastvale Calif
    1,797
    Quote Originally Posted by Sentinelist
    P0141 shows heater circuit, that should not be related to the condition of the catalytic, check continuity on the heater side of the sensor if it checks out then start the diag on the vehicle side
    Mar 2012
    Dallas, TX
    117
    First thing's first... if you're standing in front of the truck... is bank 1 the left (passenger) side?
    I was hoping it wasn't the cats... I also had to replace both of them on an 04 Grand Cherokee Ltd. last year (right before I sold it, the ESV replaced it) at a similar mileage. Actually got decent units off Amazon...
    Mar 2011
    speedwell tn,
    11,884
    Bank 1 is the drivers side bank 2 is the passenger side
    Mar 2012
    Dallas, TX
    117
    Thanks. I swapped the new sensor back to bank 1, had it reset, and it's come back again... does not show for both sides, just Bank 1 Sensor 2 still (both codes, redundantly).
    Is it the cat in that case? It seems like it, but I'd like some competent confirmation from someone who knows for sure. And if so, Magnaflow or Walker? Or recommendations? I would go ahead and do both if I must...
    Mar 2011
    speedwell tn,
    11,884
    I would check the wiring for possible damage before replacing stuff like this
    Mar 2012
    Dallas, TX
    117
    Quote Originally Posted by the cadillac man View Post
    Which part of what wiring specifically?
    Mar 2011
    speedwell tn,
    11,884
    The wiring for the 02 sensors as it sounds like a wiring issue since you tried the sensor in a different position and the issue didn't move with the sensor
    They go to the PCM if you want a wiring diagram to check continuity I can email you one
    If the wiring checks out then it may be the PCM going flaky(it is possible)
    Mar 2012
    Dallas, TX
    117
    Ok, I don't have a great way to do this beyond looking at the wires at the harness and making sure they're still snuggly in place. Maybe I need to visit a muffler shop like Midas to diagnose/check continuity? Or is there an easy DIY way to do so? You can E-mail me what you have at forums at synthesistechnologies dot com. Thanks.
    Mar 2011
    speedwell tn,
    11,884
    If you don't feel confident at doing it then I would suggest going to the muffler shop(just let them know what you have done so far)
    Mar 2012
    Dallas, TX
    117
    Ha, plenty confident, just don't know what to check (nor do I have a good tool to do it). Taking this to Midas in the next few days. Will post back.
  16. #14
    Mar 2011
    speedwell tn,
    11,884
    Ok I would go to a muffler shop if you ain't got the tools to do it
    I wasn't questioning your confidence one bit
  17. #15
    Mar 2012
    Dallas, TX
    117
    It was indeed a wiring issue! According to my shop, the driveshaft somehow tore up the wiring harness- explains why replacing the sensor did nothing. They repaired the harness for 2 hours of labor and the CEL went away, and so far is staying away. I'll probably run it up to the OK border and back tonight to make sure so I can get it inspected ASAP now- am a month late. Very happy with this result. Tempted to put the original O2 back in but won't tempt fate... will at least have a working spare I can use in a pinch now. But FYI for anyone else who runs into this, odd resolution for sure.
  18. Remove Advertisements
