Front A/C fan not blowing
Results 1 to 15 of 15
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, Front A/C fan not blowing in Cadillac Escalade Forums; It operates while underway but when I stop it slows way down...what gizmo is acting up to cause this to ...
    sprink60's Avatar
    sprink60 is offline Cadillac Owners Fanatic
    Automobile(s): 2005 Escalade ESV
    Aug 2012
    West Palm Beach, Fl
    234
    It operates while underway but when I stop it slows way down...what gizmo is acting up to cause this to happen?
    wesyder's Avatar
    wesyder is offline Cadillac Owners Connoisseur
    Automobile(s): 08 Escalade ESV awd, 05 Yukon Xl Denali awd, 06 SRX sold
    Mar 2009
    Eastvale Calif
    1,793
    Quote Originally Posted by sprink60
    If its the blower motor acting up, possibly the blower motor resistor
    the cadillac man's Avatar
    Mar 2011
    speedwell tn,
    11,884
    Either the blower motor or blower motor control module
  5. #4
    sprink60's Avatar
    Aug 2012
    West Palm Beach, Fl
    234
    Re: Front A/C fan not blowing
    Thanks guys...seems like this afternoon it started working as it should...but I can't explain why. FYI...some times while sitting at a stop I hear a strange tapping from behind the dash on the passenger side...any thoughts on this one?
  6. #5
    Mar 2011
    speedwell tn,
    11,884
    The tapping is the actitutior traveling(or dithering) but if the blower motor isn't working it can only one of two things bad blower or bad blower control module(both are easy to replace)
    To rid the traveling pull the hvac fuse in the under hood box for a couple mins then put it back in turn the key to run for a couple mins then back off and start the truck the hvac system should do a relearn process(mine did this and that is how I fixed it)
  7. #6
    sprink60's Avatar
    Aug 2012
    West Palm Beach, Fl
    234
    I will try this. Mine is also doing the "fan/blower running after shut down" dealeo. Have you replaced your blower resistor/module? Is this a common part?
  8. #7
    Mar 2011
    speedwell tn,
    11,884
    If you blower is running with the key off then its the blower control module
  9. #8
    sprink60's Avatar
    Aug 2012
    West Palm Beach, Fl
    234
  10. #9
    Mar 2011
    speedwell tn,
    11,884
    It looks like its the right part
  11. #10
    sprink60's Avatar
    Aug 2012
    West Palm Beach, Fl
    234
    OK..it was the resistor. GM has a kit that upgrades the resistor to a new style and it comes complete with a retro-fit pigtail and instructions....$60 out the the door at http://stores.ebay.com/Number-1-Gm-Parts. They are local for me so I just walked in a picked it up.
  12. #11
    wesyder's Avatar
    Mar 2009
    Eastvale Calif
    1,793
    Sweet
  13. #12
    OCShaun is offline Cadillac Owners Member
    Automobile(s): 2004 Escalade ESV
    Jun 2015
    37
    1
    So I have a 2004 Escalade ESV and am having the same problem with the front fan not blowing but rear works fine. Are there two separate blower resisters for rear and front? I looked up the part for the blower resister and it looks so what simular but you can noticeably tell it's different.... If so, where would the "front blower resister" be located?
  14. #13
    blaze190 is offline Cadillac Owners Fanatic
    Jul 2014
    135
    Your blower motor control module should be located by the fan and kinda behind and below glove compartment. You will most likely have to remove the cover panel under glove compartment to get to the blower and blower control module
  15. #14
    stanterra is offline Cadillac Owners Member
    Automobile(s): 2005 Escalade ESV, 1976 Eldorado
    Jun 2016
    1
    Quote Originally Posted by blaze190 View Post
    I have the same exact problem and have replaced the resistor and the motor and still nothing....What else could it be?
  16. #15
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by stanterra View Post
    likely the havoc control module is bad.
  17. Remove Advertisements
