Rear Access Open Message
Results 1 to 9 of 9
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, Rear Access Open Message in Cadillac Escalade Forums; Hi guys, I'm seeing a "rear access open message" on my 03 escalade, even though the latch and the glass ...
    af908 is offline Cadillac Owners Member
    Automobile(s): Escalade
    Apr 2013
    30
    17
    Hi guys, I'm seeing a "rear access open message" on my 03 escalade, even though the latch and the glass are tightly closed. I just bought a multimeter, could someone tell me how to use it to verify which sensor of the three (one on glass latch, two on trunk latch) is bad?
    Jophusp's Avatar
    Jophusp is offline Cadillac Owners Fanatic
    Automobile(s): 2003 Cadillac Escalade XS-500
    Nov 2012
    33
    102
    Re: Rear Access Open Message
    Mine does the same thing from time to time, if I do not shut it hard enough. Seems to be the main trunk latch though, since it only does it after I open the whole door, vs just the glass. You might be able to tell that way. Sorry, never used a multimeter.
    the cadillac man's Avatar
    Mar 2011
    speedwell tn,
    11,884
    I have this message pop ever so often and I normally take wd-40 to all three catches and it goes away
    Apr 2013
    30
    17
    Yeah i tried that, didnt work for me...
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by af908
    Then the inside trim panel will need to be removed to gain access to the latches
    Apr 2013
    30
    17
    Quote Originally Posted by the cadillac man View Post
    Yeah, the two door latches are easily accessible just have to remove the torx screws. The glass latch i would have to remove the trim..... Does the trim just pull off? I dont want to break anything.
    Does anyone know how to diagnose that it is indeed the door sensors versus needing a replacement BCM? Ive heard there is a way to test if it is an open or closed circuit but im not sure how exactly to go about that..
    Mar 2011
    speedwell tn,
    11,884
    If you have a multi meter that checks the ohms rating you can use that
    I am pretty the trim panel just pops off(I can check my service manual to be sure)
    Apr 2013
    30
    17
    Thanks, but how would i go about checking the ohm rating? Do i connect the multimeter with the trunk sensors plugged in, or unplugged? If they are plugged in i would image i would have to strip some of the rubber off right? Also what should i be looking for in terms of an ohm rating? Sorry i'm really new with multimeters...
    Mar 2011
    speedwell tn,
    11,884
    Check the sensors with them unplugged from the trucks harness to prevent a false reading
    As far as the reading anything but 1 (it may be different with different meters) is ok with the latches closed(take something and push them in before testing)
  12. Remove Advertisements
