squeaky noise on steering wheel
Page 1 of 2 12 LastLast
Results 1 to 15 of 22
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, squeaky noise on steering wheel in Cadillac Escalade Forums; Recently my 05 escalade started to have a squeaky noise when turning the steering wheels. It seems from inside the ...
    icaddy is offline Cadillac Owners Fanatic
    Sep 2012
    42
    137
    Recently my 05 escalade started to have a squeaky noise when turning the steering wheels. It seems from inside the car, not underneath the hood. I found a thread in the forum that someone recommend to use Super Lube. I tried it but still have the squeaky noise. Where should I check?
    thanks
    Sep 2012
    42
    137
    Re: squeaky noise on steering wheel
    bump up. any help please
    Wysguy is offline Cadillac Owners Member
    Automobile(s): '06 STS(V8), '06 XLRV, '05 Escalade EXT,'04 DTS, '91 Seville
    Jul 2012
    LA/LV/Bullhead City
    15
    I have a clicking/Squeeky on my '05 also looking for help
    djais1801's Avatar
    djais1801 is offline Cadillac Owners Fanatic
    Automobile(s): 2004 EXT Sable Black
    Feb 2011
    NJ
    47
    246
    I have a squeeky/rubbing sound that i actually feel on the steering wheel only when turning left...i flushed the system and added lucas additive and still have it...my tech lubed the shaft at the firewall and it dampened the sound..but it's back. if you find a solution...let a brother know!
    the cadillac man's Avatar
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by djais1801
    I'd say the shaft needs replacing (not sure)
    Chip Potts is offline Cadillac Owners Member
    Automobile(s): 2003 Escalade ESV
    Sep 2012
    57
    4
    I have the same problem with my 2003 Escalade and my 2005 Chevrolet Silverado. Took the truck in when it was under warranty and the only solution the GM guys offered was was replacing the steering shaft assembly.
    Jul 2012
    LA/LV/Bullhead City
    15
    Not what i wanted to hear but figured that was the solution
    djais1801's Avatar
    Feb 2011
    NJ
    47
    246
    Quote Originally Posted by Chip Potts View Post
    did that take care of the issue?
    dds1969 is offline Cadillac Owners Member
    Automobile(s): 2005 Escalade
    Aug 2010
    1
    Hi guy. Sometimes a squeak/vibration can develop at the firewall boot. I'm not sure of the design on the GM's, but some synthetic lube can be applied where the steering shaft passes through the firewall boot. Oil/solvent based lubes may deteriorate the boot. Don't get excessive with the lube, as it will drip and collect dust/grime.
    djais1801's Avatar
    Feb 2011
    NJ
    47
    246
    Quote Originally Posted by dds1969 View Post
    my caddy tech friend lubed at the firewall boot, didn't change anything
    OneLuv1979 is offline Cadillac Owners Member
    Automobile(s): 2004 Escalade
    May 2013
    Wellington,FL
    38
    44
    Wow I have the same issue on my 04 w/43k miles just a clunk..
    I did some research and found the I Connecting Shaft is notorious for this.
    Shocked this site was not all over it.
    Its actually a pretty easy install...
    Here are a few links to articles that might help...
    I hope its ok to post other sites... Just figured they could help out.
    The second link has step by step install w/pics.
    I have only had my Escalade a week so I have not changed it yet but I do plan on it soon.
    Dorman makes a replacement I can buy for around $55 on ebay and they claim it don't have the same issue.
    Sounds like a 10-20min install tops
    http://gmcowners.com/gmc-forum/showthread.php?t=16293
    http://www.fourwheeler.com/techartic.../photo_01.html
    Sep 2012
    42
    137
    I lubricate the steering wheel and it seems the noise was gone. Here is a picture showing where I sprayed lubricant. I used Super Lube from Home Depot.
    djais1801's Avatar
    Feb 2011
    NJ
    47
    246
    Quote Originally Posted by icaddy View Post
    did you remove steering wheel...or just spray lubricant into those crevaces?
  16. #14
    grayparatrooper is offline Cadillac Owners Member
    Apr 2013
    89
    I have a slight squeak as well but isn't tell if its from inside or outside.
  17. #15
    Sep 2012
    42
    137
    Quote Originally Posted by djais1801 View Post
    I just spray into those crevices.
  18. Remove Advertisements
