EXT Tailgate lock.
Results 1 to 5 of 5
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, EXT Tailgate lock. in Cadillac Escalade Forums; Has anyone had any issues with the tailgate lock? My new to me 2004 lock will not work with either ...
    65kaiser is offline Cadillac Owners Member
    Mar 2013
    Crystal Beach Florida
    59
    47
    EXT Tailgate lock.
    Has anyone had any issues with the tailgate lock? My new to me 2004 lock will not work with either of the original keys. It does turn it about to the 2 o'clock position but then stops. The previous owner says it was never replaced.
    Txao1051's Avatar
    Txao1051 is offline Cadillac Owners Member
    Automobile(s): Escalade EXT
    Feb 2013
    28
    98
    Quote Originally Posted by 65kaiser
    I have the same issue I have to keep turning and finally forced it. After I unlocked it I left it alone for fear of bending the key
    jjtwomey's Avatar
    jjtwomey is offline Cadillac Owners Member
    Automobile(s): 2002 Escalade 500XS
    Nov 2012
    Massachusetts
    58
    Quote Originally Posted by 65kaiser View Post
    Try pushing the tailgate in as you turn it seems to work when mine gets stuck
    coprod230 is offline Cadillac Owners Member
    Jul 2013
    3
    Re: EXT Tailgate lock.
    Had the same issues with my 2006 ext not long ago. I found that it was seized. Spay a lot of lubricant on the mechanism inside the tail gate behind the handle. With the tailgate in the unlock position work the handle a lot. If you still have the issue. Open the tailgate and look on both sides where the safety straps are. There are two star bolts that need to be removed. After removing you will pull the latch out which is attached to a metal rod which is attatched to the locking mechanism. Lubricate and work by hand. Repeat to other side. That did the trick for me. Drove me nuts till I got off my a$$ and figured it out.
    Mar 2013
    59
    47
    Sorry for not posting an update to this thread. I had to remove the lock, lots of rust and it was all bound up. After much spray lube and manipulation its all fixed now.
  8. Remove Advertisements
