Results 1 to 7 of 7
Thread: 2002 3rd brake light.
    coastie13 is offline Cadillac Owners Member
    Automobile(s): 2002 escalade
    Apr 2013
    Hi all,
    I have a 2002 Escalade and the 3rd brake light isn't working. Also the switch to lock in the back or the cig. lighter are not working. I checked the power to the 3rd brake light and didn't get any. The mech. said it wasn't the blubs and Cadillac said they wanted $600.00 to fix.
    Can anyone help or lead me in the right direction?
    Thanks.
    shore is offline Cadillac Owners Enthusiast
    Automobile(s): 2007 Escalade
    Nov 2008
    Port Orange, Florida
    44
    637
    Re: 2002 3rd brake light.
    you need to post this in the right section. This is the 07-up section.
    MrHolland's Avatar
    MrHolland is online now Super Moderator
    Automobile(s): 2010 Platinum Escalade, 1996 Fleetwood Brougham
    Jul 2010
    Midwest
    5,683
    Moved to the proper section.
    Welcome to the forum!! Lots of good people and info in here. Enjoy your stay!!!
  5. #4
    the cadillac man's Avatar
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by coastie13
    Hi all,
    Thanks.
    There is a fuse labeled cigar in the under hood fuse box
    Along with one label chmsl
    Not sure on the lock switch
  6. #5
    Logandiagnostic's Avatar
    Logandiagnostic is offline Cadillac Owners Connoisseur
    Automobile(s): 2001 DTS, 2005 Mustang GT, 2010 MINI S
    Feb 2003
    Franklin, TN
    1,118
    It can be confusing...The Cadillac dealership solution to the problem is to throw a new $600 lamp at it..
    The third brake light is on a different fused circuit then the lower tail lights. So it is common to have working lower brake lights and 'no' third brake light.
    The third brake light also shares the fuse with the trailer hitch. So if you ever pull a trailer or have recently used a trailer be sure to inspect the fuse.
    2002s have a different dashboard then 2003s and later. And different fuses for the third brake light.
    2002 models. Be sure to inspect fuse #16 in the underhood junction/ fuse block.
    2003 and latter models. Be sure to inspect the 'VEH CHMSL' fuse in the drivers side dashboard fuse block.
    The problem can certainly be in the lamp. But that does not sound like the case here.
    If the problem is in the lamp, serviced lamps are available.
    www.ledfix.com
  7. #6
    Apr 2013
    I checked all the fuses and they are good. I did not see one that said trailer brake, just back-up and RH and LH Tail. My under hood box dosn't list the fuses by number so I could not check the #16 fuse.
    If the 2002 is different, then I guess the owners manual on the sticky and the wire diagram will be differt also?
  8. #7
    Feb 2003
    Franklin, TN
    1,118
    2002...Fuse #16....underhood junction block. I attached a pic.
    The lamp pigtails...can also get damaged. You need both 12v positive and ground at the lamp plug....with the brakes 'on' of course.
    If fuse #16 is good, and you have 12v B+ and ground at the lamp plug. The problem is inside the lamp.
    www.ledfix.com
  • You may not post replies
