How do I bench test a 2002 Cadillac Escalade EXT 3rd brake light (off of the truck)? - Page 2
Page 2 of 2 FirstFirst 1 2
Results 16 to 19 of 19
Like Tree1Likes
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, How do I bench test a 2002 Cadillac Escalade EXT 3rd brake light (off of the truck)? in Cadillac Escalade Forums; Yeah that is the correct procedure to test the light. A fuse is always a good idea good job! The ...
  1. #16
    N*Caddy's Avatar
    Nov 2006
    Toronto, Canada
    38
    6,405
    Re: How do I bench test a 2002 Cadillac Escalade EXT 3rd brake light (off of the truc
    The red wire is positive terminal and the black wire is the negative (GND) terminal.
    For the LEDs the polarity is important (LED = Light Emitting Diode) so basically an LED is a diode. And just like a diode it will conduct electricity one way and will be very high resistance (we can approximate it as infinite) the other way. There will be no damages to the LEDs if the polarity is reversed so you can test with confidence if one way doesn't work then just swap the wires (change the polarity) and it will lit.
    98cadillac and 98cadillac like this.
  2. #17
    the cadillac man's Avatar
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by N*Caddy
    Some LEDs can be damaged by reverse polarity hence why I said not to reverse the connections I didn't know it wouldn't harm these
  3. #18
    98cadillac is offline Cadillac Owners Fanatic
    Automobile(s): 1998 Cadillac Seville STS
    Feb 2013
    306
    Quote Originally Posted by N*Caddy View Post
    Thank you for the reply and the details. The fuse was the cadillac man's idea, so thanks to him for that.
  5. #19
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by 98cadillac
    It's better to be safe then sorry(I learned that when installing my audio gear in my car(long process)
  6. Remove Advertisements
