2005 diff question
Results 1 to 14 of 14
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, 2005 diff question in Cadillac Escalade Forums; 2005 escalade AWD 6.0 engine. I have a diff issue but I can't fine the leak. I park The truck ...
    Triniboy 1234 is offline Cadillac Owners Member
    Automobile(s): 2005 Cadillac Escalade
    Jun 2011
    28
    2005 diff question
    2005 escalade AWD 6.0 engine. I have a diff issue but I can't fine the leak. I park The truck and put a cloth under and nothing it stop leaking. The problem is it might start back again. Can someone please help.
    wesyder's Avatar
    wesyder is offline Cadillac Owners Connoisseur
    Automobile(s): 08 Escalade ESV awd, 05 Yukon Xl Denali awd, 06 SRX sold
    Mar 2009
    Eastvale Calif
    1,797
    Quote Originally Posted by Triniboy 1234
    Looks like an axle seal... Probably stopped leaking cuz the fluid level is down
    Jun 2011
    28
    Re: 2005 diff question
    Anyone knows how to change this?
    mikedyk43's Avatar
    mikedyk43 is offline Cadillac Owners Fanatic
    Automobile(s): 2006 Escalade
    Sep 2011
    Mission Viejo, CA
    38
    470
    Quote Originally Posted by Triniboy 1234 View Post
    Unscrew the six bolts holding the front axle to the front differential and let the axle hang down. Take a large hammer and a long punch (or flathead screwdriver) and tap the shaft out that the axle was bolted to. With the shaft removed you can remove the seal and replace it with a new one. The seal is pretty inexpensive at your local autoparts store. Don't be afraid to give the shaft a good whack, that is the correct way to remove it. Below is picture of the front diff with the shaft moved out so you can see the seal.
    Edit : After looking at your picture again, I can see your leak is on the driver's side. Same procedure as stated above, the shaft is only shorter :-)
    Jun 2011
    28
    Does anyone have a service manual that I can take a look at?
    flyingdutchman is offline Cadillac Owners Fanatic
    Oct 2004
    343
    See link posted by Mikedyk43
    Digital Escalade Service Manual Downloads
    http://www.cadillacforums.com/forums...e-manuals.html
    Jun 2011
    28
    The link does not work I still need the service manual can someone please help me
    the cadillac man's Avatar
    Mar 2011
    speedwell tn,
    11,884
    If you want I can email them to you if provided link doesn't work just pm me your email
    Oct 2004
    343
    Jun 2011
    28
    I unscrew the flange but nothing happen does it have a clip to come out or do I have to unscrew the diff?
    Jun 2011
    28
    Can i fix this problem without taking the diff out??
    YoshiMan's Avatar
    YoshiMan is offline Cadillac Owners Fanatic
    Automobile(s): 1975 Coupe Deville D'Elegance
    Oct 2012
    Denver, CO
    32
    261
    As i am in the process of pulling my differential out to get to the oil pan, just from my recollection, it seems that there would be enough room to pull the drivers side shaft out without having to remove it. The CV shafts can be unbolted and scooched out of the way
    Jun 2011
    28
    Where the seal was sitting there is a little bit of rust on the shaft. Should I buy a new shaft?
  16. #14
    YoshiMan's Avatar
    Oct 2012
    Denver, CO
    32
    261
    so long as it's smooth i wouldn't worry about it. If it's pitted and feels rough, then you may try smoothing it out with a dremel or some other method. What part of the country do you live in? Looks like you've had alot of salt exposure?
  17. Remove Advertisements
