05 Escalade Base question
Results 1 to 13 of 13
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, 05 Escalade Base question in Cadillac Escalade Forums; I'm back on the search and I found a vehicle that has potential. It's an hour away. The seller said ...
    spirit man's Avatar
    spirit man is offline Cadillac Owners Member
    Feb 2013
    44
    Question05 Escalade Base question
    I'm back on the search and I found a vehicle that has potential. It's an hour away. The seller said the only problem was the fuel gauge hand doesn't work. He said the instrument cluster needs to be replaced and the mileage adjusted.
    Since my mechanic is located where I live and I don't know a thing about Escalades, what should I specifically be looking for. I have a volt meter and an ODB2 scanner.
    the cadillac man's Avatar
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by spirit man
    Take the truck for a test drive before making a decision
    the voltage gauge could just be a stepper motor bad(easy to fix if you know how to soldier)
    spirit man's Avatar
    Feb 2013
    44
    Re: 05 Escalade Base question
    The guy said it was AWD. I checked the VIN number and the 5th digit is C. I read that C is 2WD and K is AWD/4WD. On to the next one....
    Mar 2011
    speedwell tn,
    11,884
    One way to tell is the front axle that and the engine in certain years(they were all wheel drive with the 6.0)
    YoshiMan's Avatar
    YoshiMan is offline Cadillac Owners Fanatic
    Automobile(s): 1975 Coupe Deville D'Elegance
    Oct 2012
    Denver, CO
    32
    261
    I second what he said, Make certain you drive it and listen for oddball driveline noises. The most common issues these have from what i've heard from others are the front differentials, the transfercases, and various little electrical things. Make certain you check EVERY electrical item inside the car, becuase as most of them are pretty simple to fix if you are mechanically inclined, they can get very expensive if shop do them for you.
    Also, check the oil gauge and see around where it averages. should be about half-way up the gauge. sometimes the O-ring between the oil pump and the pick up tube deteriorates, causes it to suck air and eventually leads to the oil pan needing to be dropped to fix it.
    spirit man's Avatar
    Feb 2013
    44
    I appreciate the tips!
    miketaylor4's Avatar
    miketaylor4 is offline Cadillac Owners Member
    Automobile(s): 2004 Escalade, 2005 silverado ss, 2002 F250
    Apr 2013
    26
    13
    carfax is usually filled with answers, worth the 20 bucks
    jnrsesv is offline Cadillac Owners Enthusiast
    Automobile(s): '05 ESV Platinum
    Feb 2010
    Sunny South Carolina
    912
    The "mileage needs adjusted"?
    Hmmm I would be more worried about that.
    spirit man's Avatar
    Feb 2013
    44
    Quote Originally Posted by jnrsesv View Post
    This one didn't make the cut. Plus, it was RWD. I specifically said I wanted AWD.
    Mar 2011
    speedwell tn,
    11,884
    I would have passed on the mileage needs adjusting(that means its been tampered with and is not good)
    caddydaddy's Avatar
    caddydaddy is offline Cadillac Owners Connoisseur
    Automobile(s): 2005 Escalade 6.0L 2WD, 2007 Jeep Grand Cherokee Limited CRD
    Jan 2003
    Gales Ferry, CT
    35
    3,717
    Quote Originally Posted by the cadillac man View Post
    My 2005 has the 6.0, but is 2WD.
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by caddydaddy
    Yeah I forgot that gm dropped the smaller engine in 05 my bad
    Silent_Assasin's Avatar
    Silent_Assasin is offline Cadillac Owners Fanatic
    Automobile(s): 2005 Escalade EXT - Rip Tide Blue
    Mar 2013
    30
    200
    Quote Originally Posted by spirit man View Post
    I dont think I would even take a chance on the guy if hes obviously not being honest to you about stuff like that! Just my opinion!
  16. Remove Advertisements
