2005 Escalade ESV: Do I need new shocks?
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 18
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, 2005 Escalade ESV: Do I need new shocks? in Cadillac Escalade Forums; My 2005 Escalade ESV Platinum with 105,000 miles. I bought it last summer with 98,000 and new tires. The tires ...
    bowwowscaddy's Avatar
    bowwowscaddy is offline Cadillac Owners Member
    Automobile(s): 2005 Escalade ESV Platinum
    Feb 2012
    Langley AFB, VA
    52
    14
    98,000 and new tires. The tires are already cupping and I get a slight rumbling at
    highway speeds which gets worse the faster I go. I'm fairly sure these are original
    shocks. Does any of this sound like I need new shocks?
    Thanks.
    the cadillac man's Avatar
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by bowwowscaddy
    Thanks.
    The rumbling noise is more likely a bearing in need of replacing
    Along with the front end needing a realignment
    The shocks don't cause nether issue
    sprink60's Avatar
    sprink60 is offline Cadillac Owners Fanatic
    Aug 2012
    West Palm Beach, Fl
    234
    Re: 2005 Escalade ESV: Do I need new shocks?
    Quote Originally Posted by the cadillac man View Post
    ...but...at 105K I would start budgeting for R & R shocks soon.
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by sprink60
    Sprink you have a point on the shocks(worn shocks make a squeak noise though)
    Though the noise he is describing is a bearing problem(been there) as my previous car had the front wheel bearing wear out at 130,000 miles(it was one then the other later on)
    The wheel alignment is mentioned(uneven tire wear(I had to do mine when I got my tires changed))
    Feb 2012
    Langley AFB, VA
    52
    14
    I 'll have a mechanic check it out. Good call that it might be a bearing. Anyone know how much a new bearing and front end alignment might cost? I'll check with my local Cadillac dealer and the mechanic at a local Western Auto, auto repair/parts business, to get a comparison.
    6lbsofSound is offline Cadillac Owners Fanatic
    Automobile(s): 03 Escalade
    Aug 2012
    193
    Cupping on tires is caused from worn shocks. If the tread pattern is wearing uneven then that is signs of the alignment being off.
    To replace the bearing you need the entire hub as its cheaper and cost like 50 bucks plus labor. The alignment varies I paid 80 for a full 4 wheel alignment when I got new tires 2 months ago.
    Mar 2011
    speedwell tn,
    11,884
    The cost of the alignment depends on where you go
    TLMC is offline Cadillac Owners Member
    Automobile(s): 2011 Escalade 1969 ss396 chevelle 1967 GTO
    Nov 2011
    BOYNTON BEACH,FL
    62
    76
    There is no 4 wheel alignment on an escalade, front wheel only. The rear end assembly is fixed not independent.
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by TLMC
    Yep or the cost for the alignment would be higher mine was around 40.00 bucks to do and has been great since(mine would pull a bit to the right before realignment)
    djais1801's Avatar
    djais1801 is offline Cadillac Owners Fanatic
    Automobile(s): 2004 EXT Sable Black
    Feb 2011
    NJ
    47
    246
    yes...cupping of wheels is def sign of worn shocks
    kdbvulcan is offline Cadillac Owners Member
    Automobile(s): none
    Jul 2011
    14
    what bearing do yall think it is?...my 04 makes a noise up front but its starts humming on and then quits on decaleration
    wesyder's Avatar
    wesyder is offline Cadillac Owners Connoisseur
    Automobile(s): 08 Escalade ESV awd, 05 Yukon Xl Denali awd, 06 SRX sold
    Mar 2009
    Eastvale Calif
    1,802
    Quote Originally Posted by kdbvulcan
    Mine does that as well but im pretty sure its the front diff, both wheel bearings have been changed before
    Automobile(s): none
    Jul 2011
    14
    about how much did it cost?
    [QUOTE=wesyder;3358073]Mine does that as well but im pretty sure its the front diff, both wheel bearings have been changed before[/QUOTE about how much did it cost to replace both of them?
  16. #14
    Feb 2012
    Langley AFB, VA
    52
    14
    Shocks are good. My mechanic suggested to get all four wheels rebalanced and a front end alignment. I did that and all is good. He also changed the front and rear differentials and transfer case fluids. For $220.00 total for parts and labor. My local Cadillac dealer wanted $450.00+ for the same service.
  17. #15
    Typer2k1 is offline Cadillac Owners Member
    Automobile(s): 2004 Escalade ESV
    Apr 2013
    7
    My Escalade is rumbling from the front end too, it's more noticeable above 20-30mph with my foot on the gas, but when I let off the accelerator it goes away. I've seen someone on eBay that will rebuild your front diff for $850 shipped. I think their name is Gmgearheads and they use ac delco parts
  18. Remove Advertisements
