Oil Question
Results 1 to 4 of 4
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, Oil Question in Cadillac Escalade Forums; Hi, i'm new here, my name is Joe and would like to ask a question about oil. Is it possible ...
    cooldaddypop is offline Cadillac Owners Member
    Automobile(s): 2003 Escalade EXT
    Apr 2013
    Venice Fla
    60
    Oil Question
    Hi, i'm new here, my name is Joe and would like to ask a question about oil. Is it possible to damage the motor using just a conventional motor oil? I see the recommendation is a synthetic oil but can damage be caused by using conventional oil 1 or 2 times?
    The reason i'm questioning this is i'm having issues with oil pressure, the gauge bounces up and down and the bell dings.Seems to be doing it when the car is accelerated after warm up. Been reading about an oil pick up tube o ring problem. Not sure if I should go after the sender or something other. Thanks
    the cadillac man's Avatar
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by cooldaddypop
    Different oils won't damage anything it seems like the pick up tube o ring is at fault hence the gauge going nutty it could be the sender if the ring is ok
    wesyder's Avatar
    wesyder is offline Cadillac Owners Connoisseur
    Automobile(s): 08 Escalade ESV awd, 05 Yukon Xl Denali awd, 06 SRX sold
    Mar 2009
    Eastvale Calif
    1,796
    Id go after the sender first since its easier if not then the o-ring
    Apr 2013
    Venice Fla
    60
    Re: Oil Question
    Thanks guys thats what i'm kinda thinking.
  7. Remove Advertisements
