Results 1 to 5 of 5
Thread: Transfer case part number
    pinnacledbm is offline Cadillac Owners Member
    Automobile(s): escalade
    Apr 2013
    I have been advised that I need to replace the transfer case (and innards) on my 2006 Escalade Ext Pickup. The garage mentioned that they would also replace a gasket and an outer hose.
    Can someone advise what the relevant part numbers are for each of these items so that I can be sure I order and ship the correct parts.
    Thanks
    YoshiMan's Avatar
    YoshiMan is offline Cadillac Owners Fanatic
    Automobile(s): 1975 Coupe Deville D'Elegance
    Oct 2012
    Denver, CO
    32
    261
    Re: Transfer case part number
    A Brand new transfer case from GM is going to be prohibitively expensive! it would be much more cost effective to get yours rebuilt
    the cadillac man's Avatar
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by YoshiMan
    I second that new factory parts like this are pricer then rebulit
  5. #4
    Apr 2013
    I notice you can purchase an overhaul kit - will that do it ?
    Alt I ship over here a rebuilt one and then sell on the old case. Not sure how easy to replace - is it just remove and fit other or is there any balancing / special tools needed. The list of part included gasket and hoses
  6. #5
    YoshiMan's Avatar
    Oct 2012
    Denver, CO
    32
    261
    Whats wrong with your current T-case? Does it have bad bearings? Or was there some sort of catastrophic failure that chewed up the gears? If it's a bearing issue, then yes, rebuilding it will address the issue.
  • You may not post replies
