Page 1 of 2 12 LastLast
Results 1 to 15 of 23
Thread: got rid of power steering whine and hard spot
    bigirb2002 is offline Cadillac Owners Fanatic
    Automobile(s): 05 escalade
    Mar 2013
    31
    119
    so before changing my fluid if i turned the wheel to the left it would hum and then there was 2 hard spots. so i drained the old fluid and put in valvoline high mileage recommended by gm. It helped with the hum but still had hard spots and still could here the hum. So i drained more fluid out and put in a half of bottle of lucus power steering treatment. drove 1 day and later that night i noticed the hard spot was much softer. Went out this morning and its completely gone. Lucus power steering treatment is good stuff.Worked as advertised.
    djais1801's Avatar
    djais1801 is offline Cadillac Owners Fanatic
    Automobile(s): 2004 EXT Sable Black
    Feb 2011
    NJ
    47
    246
    Re: got rid of power steering whine and hard spot
    def gonna try that...my fluid levels were fine, and my tech lubed the shaft going into the firewall, still same issue...pump not leaking and only on left turns do i feel this weird rubbing/noise.
    Mar 2013
    31
    119
    yup thats exactly how mine felt. mine didnt leak either and ps pump was replaced 7k ago. i just got tired of hearing it. a friend said lucus is what they use on there gm cars as preventive maintanance or to fix noise. it worked and im happy
  5. #4
    Snowboarder is offline Cadillac Owners Member
    Automobile(s): 2004 Cadillac Escalade AWD 6.0
    Jun 2012
    35
    72
    I've had this as well, wondering if it's the same problem.
    Only has happened twice. If i'm making a hard right turn (like entering a highway ramp a little too fast) something happens and I start to get this high pitched buzzing noise that seems to fluctuate in sync with my acceleration. Goes away after I restart the car.
  6. #5
    djais1801's Avatar
    Feb 2011
    NJ
    47
    246
    Quote Originally Posted by bigirb2002 View Post
    how many qts does the power steering take?
  7. #6
    Mar 2013
    31
    119
    2-3 quarts
  8. #7
    djais1801's Avatar
    Feb 2011
    NJ
    47
    246
    okay thx!
  9. #8
    Mar 2013
    31
    119
    get lubeguard ps fluide if u can or u can do there additive best on the market and gm approved. lucus did the job tho so i have no need to switch
  10. #9
    wake's Avatar
    wake is offline Cadillac Owners Enthusiast
    Automobile(s): 2007 STS-V, 2007 Escalade, 2003 Escalade EXT
    Sep 2003
    Stafford, VA
    812
    I flushed my PS last fall using the method found on here.
    The Escalades have the hydroboost system to assist in braking. To get clear fluid out of my system I went through about a gallon of fluid. The system holds quite a bit of PS fluid.
  11. #10
    the cadillac man's Avatar
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by wake
    Wow I have wondered how much the system holds since it powers the steering rack and brake booster together(it don't seem like it would hold that much)
  12. #11
    Mar 2013
    31
    119
    3 qt system however to flush it takes about 6-7 to get old stuff out without pumping it threw a machine
  13. #12
    Mar 2011
    speedwell tn,
    11,884
    Ahh I see
  14. #13
    SkyKnight is offline Cadillac Owners Member
    Automobile(s): '06 CTS Lux Perf Pkg & '05 Escalade 2WD
    Jul 2006
    83
    Quote Originally Posted by wake View Post
    I have the wining sound but no hard spots yet. What is the procedure for draining or changing the fluid?
    Thanx
  15. #14
    appleroma Guest
    Quote Originally Posted by SkyKnight View Post
    Thanx
    I post athread here on ps fluid fludh
  16. #15
    Mar 2013
    31
    119
    also hers one important step. properly bleed the system. all you do us jack the front end up so tires is off the ground. key in on position but dont crank. turn wheel all way to left then all the way to right for about 10 min.top off fluid as air bubbles come out the lines. dont let the fluid get to low or you will have to start over. now sometimes the whine come back later. if it does air is getting in somehow.
  • You may not post replies
