got rid of power steering whine and hard spot - Page 2
Page 2 of 2 FirstFirst 1 2
Results 16 to 23 of 23
Like Tree1Likes
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, got rid of power steering whine and hard spot in Cadillac Escalade Forums; sorry for bumping an old thread but Im confused whether I should use PS fluid or brake fluid? Just bought ...
  1. #16
    Gatorlac is offline Cadillac Owners Member
    Automobile(s): 02 sls
    Aug 2011
    33
    76
    Re: got rid of power steering whine and hard spot
    sorry for bumping an old thread but Im confused whether I should use PS fluid or brake fluid? Just bought an 05 escalade and sometimes its hard to steer for maybe half a second right when I start it up/put it in drive. Its not bad at all but I wanna change the fluid before it gets bad. I know its the hydroboost system that controls brakes and PS but which fluid do I use? Been reading and see people say they used PS fluid but the cap on the res says brake fluid only...
  2. #17
    the cadillac man's Avatar
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by Gatorlac
    It is the power steering pump that works the brake booster not the other way around
    The power steering pump is on the front of the engine drivers side
    Do like the op did and it should fix the issue
    Gatorlac likes this.
  3. #18
    Aug 2011
    33
    76
    ok so I should only mess with the cap on the engine and not worry about the res?
    Thanks for replying
  5. #19
    Mar 2011
    speedwell tn,
    11,884
    ok so I should only mess with the cap on the engine and not worry about the res? Thanks for replying
    Yep only the one on the power steering pump and not the one on the brakes
  6. #20
    SQUIRREL MASTER is offline Cadillac Owners Member
    Automobile(s): 2002 Escalade
    Mar 2014
    The South
    37
    Quote Originally Posted by bigirb2002 View Post
    so before changing my fluid if i turned the wheel to the left it would hum and then there was 2 hard spots. so i drained the old fluid and put in valvoline high mileage recommended by gm. It helped with the hum but still had hard spots and still could here the hum. So i drained more fluid out and put in a half of bottle of lucus power steering treatment. drove 1 day and later that night i noticed the hard spot was much softer. Went out this morning and its completely gone. Lucus power steering treatment is good stuff.Worked as advertised.
    I realize this is an older post, but if the OP used a 1/2 bottle of lucas, do you only use 2-2.5 quarts of actual fluid instead of the 3 quarts?
  7. #21
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by SQUIRREL MASTER
    I would say so
  8. #22
    Mar 2014
    The South
    37
    I figured as much. Again, I'm no master mechanic, nor do I claim to be, but 1+1=2 no matter where you're from. Thanks for the reassurance TCM.
  9. #23
    Mar 2011
    speedwell tn,
    11,884
    Glad to help
  10. Remove Advertisements
