quick ? about removing the compressor for your suspension
Results 1 to 4 of 4
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, quick ? about removing the compressor for your suspension in Cadillac Escalade Forums; A local used parts store has a compressor in stock. My ? Is while I'm removing the compressor do have ...
    chacho44 is offline Cadillac Owners Member
    Automobile(s): escalade esv
    Dec 2011
    80
    A local used parts store has a compressor in stock. My ? Is while I'm removing the compressor do have to worry about my truck losing air in the rear shocks? I never messed with this ever, compressor has not been working sinve I owned the truck and it haz never lowered so i wanna say the shocks are fine, and its not the relay. Ill do a bench test on the compressor first before I buy the other to make sure its the problem. But I just wanna make sure the truck will not lower on me while the compressor is out. Thanks
    the cadillac man's Avatar
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by chacho44
    It won't unless it is higher then normal ride hight
    I had both my shocks blow out on me and the trucks ride hight never lowered unless I had a trailer on the hitch
    Dec 2011
    80
    Re: quick ? about removing the compressor for your suspension
    It has never lowered since I owned it. I do t think the shock are blown out since its never lowered, and cause it still rides fine.
  5. #4
    Mar 2011
    speedwell tn,
    11,884
    The way to check is the spray test
    Take some soapy water in a spray bottle and soak both shocks while working the rear up and down that will tell us if the shocks have any leaks
  6. Remove Advertisements
