slight miss-no codes
Results 1 to 7 of 7
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, slight miss-no codes in Cadillac Escalade Forums; ever since i picked up the truck...it has a slight, rough idle (slight miss)..i attributed this to needing plugs/wires as ...
    djais1801's Avatar
    djais1801 is offline Cadillac Owners Fanatic
    Automobile(s): 2004 EXT Sable Black
    Feb 2011
    NJ
    47
    246
    ever since i picked up the truck...it has a slight, rough idle (slight miss)..i attributed this to needing plugs/wires as it hit 100,000 mi. replaced those and still feel the idle-could this be from leaking manifold gaskets (broken exhaust bolts)? if not, any other advice?
    6lbsofSound is offline Cadillac Owners Fanatic
    Automobile(s): 03 Escalade
    Aug 2012
    193
    Re: slight miss-no codes
    Have you tried cleaning the throttle body?
    the cadillac man's Avatar
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by 6lbsofSound
    My 03 does this and I cleaned the throttle body and put new plugs and the fuel pump is fairly new and it still has the funny idle(which bugs me to no end)
    bigirb2002 is offline Cadillac Owners Fanatic
    Automobile(s): 05 escalade
    Mar 2013
    31
    119
    just picked up my 05 4 weeks ago. mine dies this to. i have done all of the above. only thing i can think of is tps or o2 replacement
    djais1801's Avatar
    Feb 2011
    NJ
    47
    246
    If it was the TPS or O2... I would think a fault code would be produced... My throttlebody was okay
    Mar 2013
    31
    119
    read online they wont always set off a code. also read 2 cases where replacing the coil packs fixed the problem also
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by bigirb2002
    Me too and that can get pricey but may be worth the cost (for now I am putting up with it as I can't replace the coil packs)
  10. Remove Advertisements
