2002 escalade dash light and seat problems
Page 1 of 2 12 LastLast
Results 1 to 15 of 16
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, 2002 escalade dash light and seat problems in Cadillac Escalade Forums; My 2002 escalade had a bunch of lights come on in the dash like the airbag, seatbelt, battery light and ...
    Gambler is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Sep 2008
    35
    6
    My 2002 escalade had a bunch of lights come on in the dash like the airbag, seatbelt, battery light and the service ride control came on. also the fuel gauge is not working, and driver side only power seat is not working. when i put the truck in gear the doors do not lock. I have no ideas what to do, i checked the fuses and pulled the battery cable but no luck. anybody have any ideas? thanks.
    the cadillac man's Avatar
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by Gambler
    It sounds like the bcm given what is acting up as the items you listed is tinned off the bcm
    Is the radio working?(not sure if the data feed powers it up when the key is on or not
    First I would check the connections at the bcm(located behind the drivers side knee bolster) if they are clean and tight then the bcm is the culprit
    To be sure though the bcm works
    Lights both interior and exterior
    Door locks
    Seats(and memory settings)
    Wipers (front and rear)
    Rear defroster
    Gauges
    Alarm
    Windows
    Auto headlight control
    Fog lights
    If more then one thing in this list is acting up at the same time then the bcm is at fault(I know this as my previous car had bcm issues and a few things in the list would act up not fun to have your headlight turn off on you at night doing 60)
    Sep 2008
    35
    6
    Re: 2002 escalade dash light and seat problems
    the radio works and passenger side power seat works. how can i check the bcm?
    Mar 2011
    speedwell tn,
    11,884
    What else works test everything so we can try to rule out the bcm
    That includes seat warmers wipers rear defrost
    If those work then the bcm is good
    Sep 2008
    35
    6
    seat warmers and wipers work. the cruise control is not working.
    Mar 2011
    speedwell tn,
    11,884
    There is a fuse in the fuse box for the cruise control most likely the fuse is blown
    I would check the fuses on the seat if there isn't a blown fuse there is a module under the front seats
    Sep 2008
    35
    6
    I've checked all the fuses and their all good. i have a full tank with low fuel light flashes then service air ride flashes then the battery light flashes and just keeps going
    Sep 2008
    35
    6
    heres a youtube link to my dash issues, http://youtu.be/AQm65YXIcrg
    Sep 2008
    35
    6
    now all the lights are back off and my power seat is working again. so I'm thinking it must be a short somewhere, but where?
    Mar 2011
    speedwell tn,
    11,884
    Trust me I had the same issue
    The problems would go away sometimes for a few days other times it was weeks towards the end of the two years I had the car it got worse(headlights going off and on while driving at night, locks doing what they want(I walked out to the car one day to find the drivers door unlocked the next day the truck would be opened) the hvac system would go nutty
    The rear defrost would not work as long as it should (timeout was 30 mins it would go off at 15 mins)
    Gauges would act up at times(the worse part about that was the fuel the needle would go down the e then back up(each time the bcm would chime the door chime) it got so I was afraid to drive the car at night or on long trips because if this
    The deciding point was when my neighbor clipped the side of the car while it was in the shop I went shopping for a different(I figured it would have got totaled it didn't thanks to the cash for clunkers raising the value of the car) so I didn't drive after I got back and let my dad trade it in on his hummer h2
    Trust me get the truck checked out and soon before it gets worse I went through what you are now and it is NOT fun
    Ps the car would also go through batteries like crazy due to it overcharging them over a perilous of time because of the module going crazy and draining the battery slowly
    sosatime is offline Cadillac Owners Member
    Aug 2008
    47
    30
    Same lights on dash just like the you tube video. I have the same problem my driver seat does not work so I went ahead and removed the seat switch and wiggle the connector checked the power to the switch and there is power connected my power seat switch and is working but after is not working again so I went and order a new power seat switch and same thing so I"m thinking is probably a wire not making a good contact or something loose will post as soon as I find out how to fixed it hopefully tomorow I have time.
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by sosatime
    Read the whole thread
    I posted a list of stuff controlled by the bcm go through that list and see what does and doesn't work
    Aug 2008
    47
    30
    Everything on you're list works except the driver side power seat. It works for a couple times maybe a day and then it doesnt.. anything else to check suggestions please. Thanks for all the help.. very ... appreciated if I figured it out will post Asap. Thanks everyone.
  16. #14
    Mar 2011
    speedwell tn,
    11,884
    Likely its the seat module or harness
  17. #15
    Aug 2008
    47
    30
    Fixed it Gambler the seat harness from you're power seat module plugs to another connector if you're standing in front of you're seat you will see the connector under the seat that's the one that's not making a good contact so you need to get a zip tie and put it in the center nice and tight and you're done.Working great no problems and seat has been working properly also notice seat has memory as soon as you put you're key in the ignition and my truck runs better than it did. It has pep and attitude just like before. I will post pics tomorrow.
  18. Remove Advertisements
